evo 8 cam install helpp?
Old Sep 18, 2011 | 02:39 PM
taylorgang's Avatar
so I'm installing my gsc s2 cams soon and I just had a quick question... I've been getting mixed answers about using the tensioner tool. Has anyone NOT used the tensioner tool and had a successful cam install?
I'll be using this video : http://www.youtube.com/watch?v=ex-43BYrjP0 plus the help of some friends that have installed cams in other cars to do the install...
I don't have the tensioner tool and I'd rather not buy one for $50 if I'm only using it once...
Old Sep 18, 2011 | 03:20 PM
boosted2x2's Avatar
It can be done without the tool, it just takes a whole lot longer. With the tool and some zip ties I did the whole thing in under a hour.
Old Sep 18, 2011 | 03:50 PM
Hendrixmx's Avatar
I made one myself for under 5 dollars
https://www.evolutionm.net/forums/ev...oner-tool.html
Just used two nuts locked em together, so didn't need the welding.
Old Sep 19, 2011 | 11:53 AM
taylorgang's Avatar
so what exactly is the point of the tensioner tool?
Old Sep 19, 2011 | 11:56 AM
05blue8's Avatar
It releases the tension on the timing belt to give it slack so when you pop off the cam gears there is no tension. Also note I made my own and it started to bend on the 2nd use so I bought a real one off ebay. They aren't expensive at all.
Old Sep 19, 2011 | 11:58 AM
binky's Avatar
Read this:
http://www.evomoto.com/tech_info.php?tech_id=18
Also...I *BELIEVE* you can use the factory battery hold down rods as the tensioner tool.
-Bink
Old Sep 19, 2011 | 01:03 PM
BLK_EvIL's Avatar
use the tool if you dont the hydro tensioner will full extend and you have to pull the whole timing beltcover,waterpump pully, and belt off to reset the tensioner alot of wasted time just get the tool off ebay or make your own
Old Sep 19, 2011 | 09:29 PM
My03evo's Avatar
You can use the battery hold down butt I'm pretty sure you have to cut more threads. I got a long threaded rod from napa and 2 nuts tightened against each other and worked perfect. Mine was black so I think it was hardened steel which is better just lube it up good with antiseize and turn it slow and back and forth to clean out any rust or dirt, in the threads and don't need to turn it till it stops which will bottom out the tensioner. Keep the belt somewhat tight with the zipties so it can't come off the cogs on the pullies
stefenboy
Dec 9, 2015 03:20 PM
IAmADirtDude
Aug 4, 2012 12:06 AM
pettyboy69
Mar 27, 2011 07:56 PM
kaj
21
May 16, 2010 02:38 PM
use2vtec
25
Mar 29, 2005 09:02 PM
