whats the highest boost i can run?
Old Sep 27, 2011 | 10:17 PM
SSickLS1's Avatar
i have intake/full exhaust 272 cams and on stock evo8 turbo with stock injectors
whats the highest boost that i can run safely?
Old Sep 27, 2011 | 10:20 PM
prowakeskater's Avatar
I've always heard 24 untuned, 26 tuned... on 93
Old Sep 27, 2011 | 10:36 PM
sparky's Avatar
Like prowakeskater points out....it is octane dependent. That is one important factor. Also, the extent of your mod list(items such as what IC, and even what spark plugs) is important as well as the tune, the altitude above sea level, barometric conditions and ambient air temperature, even whether you are running a cat or not.
Old Sep 27, 2011 | 10:38 PM
SSickLS1's Avatar
stock plugs stock IC and 93 octane
Old Sep 28, 2011 | 05:44 AM
Danner's Avatar
I'd keep it on stock pressure till u get a fuel pump and a tune. Car runs so damn rich stock, you really need to get tune to feel best results.
Old Sep 28, 2011 | 06:04 AM
GreenAWD's Avatar
Let your tuner decide how much boost is safe for you to run.
Don't have a tuner? Get one before touching the boost controller...
Old Sep 28, 2011 | 06:07 AM
evo 9 guy's Avatar
As much boost as your tuner is able to make power with when getting a tune.
Old Sep 28, 2011 | 06:08 AM
FJF's Avatar
FJF
^^^ This!
Old Sep 28, 2011 | 06:42 AM
SSickLS1's Avatar
car has been tuned. sorry i forgot to mention that in first post
Old Sep 28, 2011 | 06:43 AM
GreenAWD's Avatar
If it's been tuned than you need to speak with your tuner and they will advise you...
Old Sep 28, 2011 | 06:44 AM
EmeryatSTM's Avatar
Then it can only run the amount of boost the tuner set it up to run.
-Em
Old Sep 28, 2011 | 08:36 AM
My03evo's Avatar
-Em
Yeah, what he said, if you go above a boost cell that he didnt tune yet your going to have some serious problems, if he didnt tune it yet than it's probably for the reason that you would run out of fuel or something. Bottom line is talk to your tuner
Old Sep 28, 2011 | 08:41 AM
ratt_finkel's Avatar
I had a similar setup on my 8. But I had a pump. With a tune I could run about 23psi on 93 octance. On race gas I could run as high as 26psi. But it was never tuned for 110octance. This was many many years ago, before map switching was possible on the stock ecu.
Old Sep 28, 2011 | 02:17 PM
jDOTc's Avatar
Originally Posted by greenawd
let your tuner decide how much boost is safe for you to run.
+1232
LVSBB6
19
Apr 16, 2023 11:56 AM
500evo
65
Jan 8, 2013 10:07 AM
GuamEVO
13
May 4, 2011 03:33 PM
dipsetinallday
29
Aug 17, 2009 09:30 PM
EvoAlex48
12
Jun 5, 2009 04:08 PM
