5 bolt outlet minus 1
Old Oct 5, 2011 | 05:45 PM
Rex915's Avatar
Question 5 bolt outlet minus 1
I bought a used 5 bolt turbo outlet on here a few weeks back; I was told it was off an old Buschur setup. However, because it was a tight and short 90 elbow to the downpipe the bottom bolt was welded shut (the circled bolt hole in the picture). I was trying to find out any insight from people who have/had similar setups as far as what is the best gasket to run and technique to tightening to avoid leaks. I tried emailing Buschur racing but I never recieved anything back (Didn't surprise me because I didn't buy it from them new)
Old Oct 5, 2011 | 05:55 PM
fre's Avatar
fre
Hopefully your flange has a wastegate hole? Unless this is a stock turbo. I have a 5 bolt Ford style flange, but on a 35R. It has a hole for the wastegate off to the left in your picture. No gasket here, just tighten the bolts good. Ff anything you could try some high temp copper stuff, but it will probably just burn off.
Old Oct 5, 2011 | 06:14 PM
Rex915's Avatar
Yeah, I have a 35r. The waistgate is on the manifold.
Old Oct 5, 2011 | 09:50 PM
awdordie's Avatar
i know of a lot of people who dont use gaskets there. a friend of mine is running a turbonetics 60-1 with a 5 bolt housing like that without a gasket and he too just ignored that bottom bolt as its a major pain to get on and off. so far it has held up without leaking without the bolt or a gasket. me personally i would run a gasket just to be safe.
Old Oct 5, 2011 | 09:58 PM
1UpMoto's Avatar
When I had it on my car I ran it with a gasket and never has any problems with it leaking.
http://www.atpturbo.com/mm5/merchant...egory_Code=GSK
Old Oct 5, 2011 | 11:37 PM
My03evo's Avatar
Lottss of people, actually most people who run turbos on the foxbody mustang only use that red rtv for between the head and manifold and they never had any issues so I wouldn't worry about using that, I would use that over using no gasket at least.
Old Oct 11, 2011 | 03:03 PM
Rex915's Avatar
Don't mean to bring this thread back from the dead. I appreciate all the helpful input, but now my main concern is about not being able to tighten the bottom bolt. I do plan on running the metal gasket with rolled edges.
Old Oct 11, 2011 | 05:06 PM
My03evo's Avatar
We have diff setups but on mine I got to the bottom bolts with a stubby 14mm wrench, got to em from the top or bottom...for the back one in my case was the hardest to get to and was not able to get to it without taking the manifold off, although I have the stock manifold and an fp black
Old Oct 11, 2011 | 05:50 PM
Rex915's Avatar
Yeah, we do have different setup. Because the bolt hole on the flange itself is welded shut (no hole) to even install a short hex head bolt.
Old Oct 12, 2011 | 03:00 PM
Rex915's Avatar
bump
Old Oct 12, 2011 | 03:08 PM
1UpMoto's Avatar
You have already been told it wont leak so why are you bumping lol.
Old Oct 12, 2011 | 03:26 PM
Rex915's Avatar
Sorry bud, I am trying to get more insight from the people who have run this 5 bolt style without being able to tighten the bottom bolt. So far all I have gotten was good advice on the gasket, but only one second hand experience about not tightening it...
WS111
Mar 22, 2017 04:45 PM
WongEvo
Jan 25, 2014 05:13 AM
Photool
Lancer Tranny/Drivetrain Tech
Mar 10, 2011 02:03 PM
N3VO
Feb 25, 2009 12:02 PM
mick82907
Jan 23, 2009 08:26 PM
