Axle popped out during Coilover install and now.
Old Oct 14, 2011 | 07:51 PM
forc3 f3d's Avatar
Also, check the axle seal on the t-case!! With the axle popping out it possibly ripped the axle seal which would also cause it to leak even more.
Old Oct 14, 2011 | 07:55 PM
NOMIEZVR4's Avatar
Just in case it is bad, I bought an axle from: http://www.carpartsdiscount.com/auto...3=81523#finder
had it in the car for over a year. Probably had 20+ launches with 5k on it, that is hard driving since this is my fun car and no issues.
Old Oct 15, 2011 | 05:03 AM
bbyevo8u's Avatar
the t-case should not whine in neutral only when your in gear! so if your hearing the whining while coasting it prob not your t-case
if you can make a video that would help..
on a side note you should be fixing your car before modding it
Old Oct 15, 2011 | 08:32 AM
sk8terdude929's Avatar
Did you have to call them? I clicked the link to check the price for them but they don't have Mitsubishi listed..
Old Oct 15, 2011 | 08:37 AM
marcusE's Avatar
Will make one today after fluid change
and trust me, I've been fixing everything the previous owner hacked up just not all in one day.
Old Oct 15, 2011 | 04:08 PM
marcusE's Avatar
Tcase was completely dry. Refilled rear diff and tcase
Found out the noise is not the Tcase but a wheel bearing or the axle itself..
I can pop it into neutral and listen to the pitch of noise from 60mph all the way down to a roll and listen to it change tones.
BaLListic_EVO
24
Oct 13, 2016 02:59 PM
stunna2o1
12
Jan 19, 2016 11:44 PM
GHEvo8
Jun 11, 2015 06:42 PM
gsteensland
Oct 18, 2012 07:40 PM
Don Q
May 10, 2012 08:11 PM
