Need main bearings for input and output shaft
Old Oct 16, 2011 | 01:27 PM
midegade's Avatar
Hi all,
I unfortunately hurt my Evo 8 5speed gearbox because it was low on oil. The mechanic did not refill the transmission with enough oil after changing a damaged transfer diff. After pulling the tranny it was found that the shaft bearings including the clutch release bearing needed replacing.
Can someone direct me to a vendor or give me part numbers for all (4) shaft bearings.
I use a W5M512X5BC gearbox which came from an Evo 8 RS with VIN# JA3AH36D55U012460.
Also, is there any recommendations on replacing any other gearbox part since it is opened now.
Old Oct 18, 2011 | 09:23 PM
midegade's Avatar
Is this a wierd thing to ask.
Has anyone ever ran on low gear oil before.
Old Oct 26, 2011 | 07:37 AM
twicks69's Avatar
I would thoroughly inspect the transmission parts further than just end shaft bearings. The center diff spider and pinion shims, the gear needle bearings, the input and output shaft inner and outer bearings, and the reverse gear needle bearing. I would also make sure you didn't burn out synchros from the low oil issue.
Shep, TRE, jack's or myself should be able to help you. Either I can simply give you part numbers or I can order/ship parts once you know what is all needed.
Thanks,
Old Oct 26, 2011 | 07:47 AM
THUB's Avatar
I got all my trans parts from jacks transmissions. they knew what I needed and got it to me without issues.
Old Oct 26, 2011 | 02:27 PM
midegade's Avatar
bearings needed
Thanks,
Hey Twicks,
I would surely appreciate getting the part numbers for the bearings.
I want to pull the box, but need to budget, since I may overhaul or upgrade.
Could you give me the # for all the bearings, input/output shafts, center diff, etc. so I can have them quoted.
The gearbox code is: W5M512X5BC, which is from a Evo 8 RS model with VIN#: JA3AH36D55U012460.
Thanks for the help.
Old Oct 26, 2011 | 02:54 PM
midegade's Avatar
Thx THUB
Old Oct 30, 2011 | 04:49 AM
midegade's Avatar
Hey Twicks,
Hey Twicks,
Jack's gave me a quote and I'm ordering on Monday.
Old Nov 25, 2011 | 10:20 PM
twicks69's Avatar
Hey Twicks,
Yeah, shoot me an email at tmzperformance@gmail.com, I didn't see this thread until now and am away from my work pc.
Cian Mcloughlin
Feb 29, 2016 01:42 PM
eddy5201314
Apr 3, 2014 03:25 AM
alvinkl
Dec 2, 2012 04:07 AM
itsjustinmeyers
Lancer Tranny/Drivetrain Tech
13
Mar 30, 2012 11:44 PM
jameswwt
13
Sep 5, 2010 06:54 PM
