Leaking Drain Plug [Fixed]
Old Oct 17, 2011 | 11:43 PM
SsZERO's Avatar
There seems to be a reasonably common issue with the oil drain plug developing a slow leak. For me, it happened this summer and I tried to fix it by replacing the crush washer...which did not help. What did work was wrapping the drain plug with some teflon sealing tape - the same one used for plumbing. After that, no more leak and the necessity of using a washer at all has been eliminated (but I still left the washer on there).
Can teflon tape handle the heat? Yes.
Will it taint the oil? No.
Will it need to be reapplied at each oil change? Up to you.
Easy, cheap fix for those of you with an annoying leak that just won't go away.
Old Jun 13, 2018 | 12:08 PM
DontStopMe's Avatar
Old i know, but thanks for posting. I may try this
chaotichoax
32
Feb 11, 2020 09:00 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
wangboy925
Mitsubishi TC-SST Discussion
Apr 26, 2016 12:19 PM
ak47po
33
Mar 21, 2016 11:31 AM
