HTA86 leaking badly....
Old Oct 22, 2011 | 04:22 PM
partyboy1122's Avatar
I know a lot of you guys run this turbo
Do you guys have an o-ring where the compressor cover meets the chra?
I have an enormous leak.
It won't even allow me to boost leak test the car above 25psi.
It was assembled by FP, I never took it apart before installing it. I did re-tighten all the 6 bolts though.
Took the compressor cover off to find no o-ring or any sealant. Pictures below.
Old Oct 22, 2011 | 04:30 PM
EvoDan2004's Avatar
These turbos do not use the rubber o rings. Put a small bead of high temp silicone in the grove and put it back together.
Old Oct 22, 2011 | 04:36 PM
That's all I needed to know. I wasn't 100% sure. Thanks man.
Old Oct 22, 2011 | 04:46 PM
EvoDan2004's Avatar
No problem. Remember Small amount.
Old Oct 22, 2011 | 04:51 PM
E-Spec@Tach Motor Works's Avatar
+1
Hey Dan, what turbo did you have when you went 10.3 on 93 octane? Quick list of mods? Stock ecu?
Old Oct 22, 2011 | 05:01 PM
EvoDan2004's Avatar
Hta86 turbo. Br cams, dog box built motor/drivetrain, di intake manifold, and so on. Some of my threads have more detail
kinglasserres
271
Jun 25, 2017 11:03 PM
ihockey1
Jun 3, 2016 10:52 AM
ihockey1
17
Oct 25, 2012 03:33 PM
Fast-Mover
13
Jul 17, 2009 02:53 PM
recompile
Sep 25, 2007 12:02 PM
