Fitting bigger turbo then driving before being mapped
Old Oct 27, 2011 | 12:26 PM
craigybaby37's Avatar
Evening all near enough got all the bits now so I can fit my gt30 setup, will I be ok to fit it then drive carefully off boost until I get the car mapped?
Engine is a 2.4 currently setup to run actuator pressure 0.7 bar from when I ran the engine in.
Craig
Old Oct 27, 2011 | 12:33 PM
binky's Avatar
You can safely drive to your tune as long as you never enter boost. Also, make sure your boost controller is turned all the way down (just as another precaution).
Do you have bigger injectors installed? If so, make sure they are scaled correctly before you drive. Ideally, you would want to leave the stock injectors in and when you get to the shop, install the injectors in the parking lot, they are easy enough to do.
-Bink
Old Oct 27, 2011 | 12:47 PM
NewEvolutionIX's Avatar
I drove my car with bigger injectors and turbo to get tuned. It was a 40 min dive and it ran fine! Just never went into boost.
Old Oct 27, 2011 | 04:26 PM
theprofessional's Avatar
i drove my also.. i just did not get into boost
Old Oct 27, 2011 | 10:54 PM
Thanks for the replys, car is fitted with 1000cc rc injectors and have been scaled up by my previous tuner.
So long as I stay off boost then should be safe enough to drive to my tuners.
Old Oct 27, 2011 | 11:01 PM
06RedRalli's Avatar
Yes.
craig05evo
16
Aug 23, 2013 09:03 AM
craig05evo
Aug 16, 2013 05:37 AM
craigybaby37
Nov 23, 2011 05:13 AM
06MREvo
36
Oct 17, 2009 08:51 AM
wtz
71
Jul 2, 2004 01:11 PM
