Need advice on selecting the turbo for my evo9
Hi
Yes I need some advice on selecting turbo for my evo 9
need some turbo that is 58-62mm
I have been looking at ..
Garret gt 3582 with 82. A/R housing with t3 manifold
and also I have been looking at the BW AirWerks turbos
Like The S300SX 8375 / s360 then 1.00 A/R twinscroll housing with twinscroll t4 manifold
but I don´t find results for those bw turbos on the evoforum
so I ask have someone here tried those turbos and liked it ?
and some dyno results ?
I have seen many results from the gt 3582r ..
on this website the say that this s360 is comparable to gt3582r with twinscroll housing..
http://www.full-race.com/store/turbo...-75-turbo.html
If you would go to something else, please tell what turbo.
whp numbers from 550 - 6xx
thanks !
thanks !
550-600 if your setup is all stock right now then probably a fp black in all honesty.. it has the best powerband.. low end and top end. if you want more then 650 tho then certainly a larger non stock frame.. like a 82 or 86 35r.
sorry but i have no experience or knowledge on the BW turbos you mentioned but there are results on the forum if you dig in the dyno section forum category.
the pte 5857 bb will spools earlier than gt3582r but will she get same hp numbers like the gt3582r with .82 housing
she will spool earlier with .63 housing
but will she spool earlier with the .82 housing.
is much difference on the journal bearing version ?
killerpenguin21
157
Oct 11, 2024 06:30 PM
Geoff Raicer
600
Dec 29, 2013 02:06 PM
Geoff Raicer
50
Sep 30, 2012 02:24 PM
