pie cut 11.5 housing vs genuine 10.5
Old Nov 6, 2011 | 07:30 AM
211Ratsbud's Avatar
Is there an interest for this? I have both, with pieces on the way to mrfred. Figured if there is interest ill do it up.
Old Nov 6, 2011 | 09:48 AM
211Ratsbud's Avatar
Observe
Old Nov 6, 2011 | 09:53 AM
211Ratsbud's Avatar
The pi cut is not %100 accurately done, but still shows you the shape of the volute. The cuts are within .25" of eachother. My big machines had a hard time clamping on such a compact figure. Fwiw.
Old Nov 6, 2011 | 10:00 AM
Aby@MIL.SPEC's Avatar
Awesome!
Are the units pictured above a 10.5 & 11.5/
if so, can you label each easier identification?
I wish i had a 9.8 to send you cut too, just for reference.
Old Nov 6, 2011 | 10:07 AM
211Ratsbud's Avatar
11.5 left10.5 right .
Old Nov 6, 2011 | 12:41 PM
Sirnixalot's Avatar
the top volute looks larger on the 11.5 but the bottom appears to be a similar size on both housings
Old Nov 6, 2011 | 01:02 PM
211Ratsbud's Avatar
Fyi the 11.5 cut like butter with a 16 tpi band saw .. the mhi.... A litle longer to cut.
The 11.5 also has a non uniform volute shape easily seen on the smaller side of the top volute.(in the bottom picture) .
Old Nov 6, 2011 | 06:09 PM
sparky's Avatar
That's some nice ****, Ratster! Your cross sectional cuts very clearly depict the difference in casting quality between the factory piece and the aftermarket one. Great job. Thank you!
Old Nov 7, 2011 | 06:13 AM
211Ratsbud's Avatar
The 11.5 is not better in any way imo .. ill cut it in another spot upon request !
Old Nov 7, 2011 | 06:19 AM
211Ratsbud's Avatar
Anyone care to donate a 9.8 that is cracked ?
Old Nov 7, 2011 | 08:22 AM
03whitegsr's Avatar
I already have a 9.8 sectioned out.
You have a PM...
Old Nov 9, 2011 | 07:42 PM
CO_VR4's Avatar
Ratsbud,
Do you think the 11.5 housing "cuts like butter" because it is cast from a softer, lower quality material?
Old Nov 9, 2011 | 08:51 PM
wshihdnevo's Avatar
Looks like the biggest difference is that the WG flapper is substantially larger than the the 10.5 housing. Thanks for the pics!
Old Nov 9, 2011 | 11:56 PM
sparky's Avatar
I realize that this is OT, but does anyone have a used 9.8cm housing gathering dust in their garage, that they no longer need and would be willing to part with for a worthy cause? I'd like to have FP cut me a 9.8 to put on my Red turbo, but they no longer have any 9.8 housings in stock.
Old Nov 10, 2011 | 03:32 AM
211Ratsbud's Avatar
I feel the 11.5 did cut easier.. I believe it may be due to material comp. But I have segments for mrfred to look into. Sry mrfred, I have not mailed them yet . Today or tomorrow ..
TopLevelPerformance
Aug 15, 2014 02:40 PM
wariosport
Southeast Region
Nov 2, 2009 12:33 PM
Mr. Evo IX
South Region
20
Jan 14, 2006 05:58 AM
calvinwch
Lancer Vendor Classifieds
32
Nov 17, 2003 07:14 PM
