Pls help me to choose WG spring rate?
Old Nov 13, 2011 | 08:51 PM
jameswwt's Avatar
Hi,
im currently running on a GT3076R turbo with Turbosmart 38mm WG.
Boosting 1.6 bar (Low) & 1.8 bar (High) and what is the ideal spring rate should i pick? Can a 1 bar spring rate do the job?
Current 38mm WG is running dual spring.
My problem is whenever high speed + rev, i have to keep on WOT (Boosting all the way) because whenever i let off the throttle a little my engine jerk vigorously and ive to immediately WOT again...What is happening?
Is it due to :
1) Tuning?
2) WG spring rate (tension to high)
3) BOV (Ive just recently installed a Turbosmart race port bov) which encounter mechanical failure just after a week installed and now after got replacement, we noticed its has a mild vacumn leak when doing boost leak test.
Thanks and hope someone can share some tips.
Old Nov 13, 2011 | 09:07 PM
n2oiroc's Avatar
sounds like your blow off valve isnt opening. as far as wastegate springs go, a 1 bar should work fine, but i always go as stiff as possible to get it close to the lowest boost i will run.
Old Nov 13, 2011 | 09:09 PM
tscompusa's Avatar
sounds like tune.. no lift to shift is probably turned on.
as for the wastegate spring.. 1 bar should be ok since youre targeting such low boost pressures. maybe 1.2 bar if you can.
the turbosmart bov.. make sure you got the proper spring in that also.
tscompusa's Avatar
posted same time as you - lol
Old Nov 13, 2011 | 09:11 PM
jameswwt's Avatar
Thanks Guys...Truly appreciate it...
But not only the engine jerk vigorously my boost meter flapping vigorously too until i WOT again...
If its a tune issue what should i tell my tuner?
Old Nov 13, 2011 | 09:16 PM
n2oiroc's Avatar
can you hear the bov releasing the air? what spring is in it?
Old Nov 13, 2011 | 09:23 PM
jameswwt's Avatar
Im not sure...I believed it come with the standard bov spring...
Honestly, the main reason i need to lift off the throttle is bcos whenever i WOT with full boosting, i heard the WG & BOV is kept open.
That's why i need to lift off a little and throttle again...
Old Nov 13, 2011 | 09:27 PM
n2oiroc's Avatar
so at wot you hear air rushing out of the bov?
Old Nov 14, 2011 | 02:55 AM
jameswwt's Avatar
I think so but WG im 100% assured.
Old Nov 14, 2011 | 09:09 PM
boonkae's Avatar
Sounds like compressor surged ...
Old Nov 15, 2011 | 02:31 AM
jameswwt's Avatar
how to over come the surge Boonkae?
Have sent for a fine tune today, and we have confirmed the WG is doing great but the Bov is kept opening when boost reach 1.6 bar.
My tuner said whenever the bov open, the AFR read much richer???
jameswwt
41
Feb 5, 2012 06:31 PM
jameswwt
Feb 1, 2012 06:41 AM
jameswwt
Jun 29, 2011 02:49 PM
05VIII
Dec 2, 2010 06:43 PM
