starting issue was fine before
Old Nov 28, 2011 | 05:53 PM
sivs's Avatar
I ordered a replacement IAC. Ordered new o rings from the dealer as well. Ill post my conclusion in a few days when the parts are in.
Old Nov 28, 2011 | 09:15 PM
usnevo8's Avatar
Im having this same problem. There are a couple differences though, I'm running e85.. and Em from STM said my injectors were to large while running a stock turbo and stock ecu.. keep us posted on how it goes, because if all else fails I'll order a new IAC.. I've actually been told it could be the IAC to begin with but didnt feel like dealing with it. Now that its colder its getting worse. Good Luck
Old Nov 28, 2011 | 09:25 PM
tscompusa's Avatar
no injectors are to large for stock ecu.. lol. mine fires cold/ warm.. sit it outside in 20F it fires up stays running..
its all in the ISCV tables + cranking ipw.. that high idle when cold is not so good for an engine either.. i removed that as well.
Old Nov 28, 2011 | 10:16 PM
usnevo8's Avatar
What exactly is the ISCV tables & cranking IPW.. my idle right now is set at 1500 because it isn't only with starting. It's also anytime I engage the clutch for example pulling out.. or if I'm going fast down the interstate and engage the clutch it drops to 500-800 rpms and wants to die, and even has sometimes.
dsmtalontsi95
Aug 25, 2018 05:44 AM
Kraise
Sep 5, 2017 05:51 PM
Toxin
Sep 9, 2013 08:31 AM
Markley02
30
Jun 13, 2008 07:43 PM
bobaab
Lancer Troubleshooting
Dec 24, 2006 11:57 AM
