444hp/412tq - Knocking on the stock rods limit?
Old Dec 3, 2011 | 02:01 PM
18bora's Avatar
Mods
HKS 7460R + Cams
Walbro Fuel pump
Vishnu- V-band 3”TBE
Megan 02 Housing
Busher’s ported exhaust manifold
ETS 3” FMIC
ETS LICP
Injen intake/UICP
Forge MBC
Twin SD clutch
PTE 1000’s
Stock DV
On 93 pump gas
Previous numbers
https://www.evolutionm.net/forums/ev...9-93-pump.html
After a few of tweaks
I had a passenger in the first run= the weight difference
Same runs/Mustang numbers
Old Dec 3, 2011 | 03:34 PM
kyoo's Avatar
wow nice numbers - i've got pretty much identical mods but nowhere near that power level. lower boost than you though. what cams and what boost controller and @psi set are you using
Old Dec 3, 2011 | 08:34 PM
sparky's Avatar
Kyoo: From what I gathered, the OP is running the HKS 274i/278e cams that come as a package with the 7460R turbo. He is controlling boost via a Forge UNOS MBC. His boost is spiking to a tad over 29 PSI and tailing off to 24 PSI. He's doing good!
Old Dec 3, 2011 | 08:42 PM
tscompusa's Avatar
looks good man. gotta love the colder weather. what did you end up doing with the clutch? just rebuilding it?
also something needs done to your rom. shoot me an email or aol, its just something simple i can tell you and you can add yourself.
Old Dec 3, 2011 | 09:22 PM
18bora's Avatar
Thanks,
What he said \/ via ZTXBoost log
It was the TOB; even with the STM stopper installed, it let go.
What are you thoughts on the 1.2 load @ 3781 RPM? My guess it’s the stock DV reaching the limit!
Old Dec 3, 2011 | 09:29 PM
kyoo's Avatar
gotcha - gooood numbers.
Old Dec 3, 2011 | 09:33 PM
diablo1's Avatar
Very nice numbers!!!
I've got almost the same mods but tune at 25psi, I put down 407whp on a very hot summer day.
Old Dec 3, 2011 | 09:43 PM
18bora's Avatar
25psi is what I normally run @ track events, but at this boost level, I was only making around 370. When I get a chance, I will check again.
Old Dec 3, 2011 | 09:53 PM
CurseDSM's Avatar
Congrats nice #s
Old Dec 4, 2011 | 12:26 AM
tscompusa's Avatar
Originally Posted by 18bora
Thanks,
1byte load and evoscan needs changed - that's just a load resolution issue.. its easy to fix.
Old Dec 4, 2011 | 07:17 AM
18bora's Avatar
Lower boost with the latest rom.
Old Dec 4, 2011 | 09:50 AM
211Ratsbud's Avatar
Is the stock rods actually the limit ? Or is it the rod bolts? I have a 71 hta and I run a slower timing curve. I'm afraid that 30 psi will peek a boo with the bottom end. 2-3 mid 13top end and 11.0 afr. Going to go do some leaner pulls.
Old Dec 4, 2011 | 09:53 AM
CurseDSM's Avatar
The tq is the killer of the stock rods and pistons. Keep that in mind
Old Dec 4, 2011 | 10:21 AM
kyoo's Avatar
Ahh - much more similar to what I'm getting now - almost identical mods except I have GSC S1
good luck
Old Dec 4, 2011 | 12:08 PM
todd6027's Avatar
2700 to 5200rpm needs a little work
