plastic clicking sound about injector clips?
Old Dec 4, 2011 | 08:29 AM
evosweens1's Avatar
like the title says. the ses light is on. i cleared the P0441 from the gas cap. Now every time i go to step on the gas when i hit full spool it falls on its face. it feels like a vacuum leak but about ten minutes ago i looked under the hood while it was running and i could here a clicking/tapping sound of something plastic in or above where the injector clips are. ideas? thanks..
Old Dec 4, 2011 | 10:20 AM
evosweens1's Avatar
ttt
Old Dec 4, 2011 | 02:07 PM
evosweens1's Avatar
bump?
Old Dec 4, 2011 | 04:32 PM
evosweens1's Avatar
no one?
Old Dec 4, 2011 | 09:24 PM
JDMwannabe's Avatar
Are you sure its just not the injectors firing? Are they the stock ones or aftermarket?
Old Dec 5, 2011 | 07:20 AM
evosweens1's Avatar
stock. it sure doesnt sound like it
Old Dec 5, 2011 | 07:23 AM
FX11's Avatar
put video up =]
Old Dec 5, 2011 | 09:29 AM
longdingydong's Avatar
my stock ones were pretty noisy. i would say do a boost leak test. see whaqt you come up with there
Old Dec 5, 2011 | 09:31 AM
dastallion951's Avatar
double check your connectors where they go on to the injectors there should be metal clips hold it on, push down on each connector make sure there secured, double check by the FPR which is on the passenger side of intake mani, make sure that vacuum line is secured with a zip tie... double check all the rest of your vacuum lines make sure there zip tied first before you do a boost leak test.
Old Dec 5, 2011 | 09:34 AM
SavageEvo8's Avatar
i would recommend a boost leak test. perhaps an injector seal has opened up, or something to that nature
BoostedFODO
Apr 19, 2018 12:18 PM
jlooney76
Jun 23, 2015 05:44 PM
SleepySamurai13
MitsubishiParts.net - WA
May 30, 2014 01:43 PM
3gEclipseTurbo
Jan 13, 2010 11:29 PM
Lou Zer
May 21, 2003 10:29 PM
