Slim Fan ?
Old Dec 14, 2011 | 06:30 AM
catman78's Avatar
Slim Fan ?
Hi all,
For those running tubular manifold with non stock turbo, did you need to switch to a slim fan?
Anyone use one of these below?
SPAL makes some of the nicest fans we've seen. They are much thinner than stock and flow very well. We carry a variety of sizes and flow rates. You will need to splice in the wiring connector. Brackets are easily made with a strip of aluminum to bolt to the stock fan mounting location or the body. Please specify if you want a push or pull fan along with the CFM.
11" Push/Pull 810 CFM $55 11" Push/Pull 970 CFM $90 12" Pull 870 CFM $60 12" Pull 1230 CFM $95 12" Push/Pull 1360 CFM $115
Old Dec 14, 2011 | 07:12 AM
evopwned's Avatar
I had twin 12" SPAL fans with my PTE 60 Trim. They weren't necessary but it sure made maintenance in the front of the car much easier
Old Dec 14, 2011 | 07:53 AM
gsrboi80's Avatar
I run an ETS turbo kit and have not run an inner fan in prob 3 years now. Never an issue with car getting hot
Old Dec 14, 2011 | 08:24 AM
CurseDSM's Avatar
If you just are looking into fans with that setup look into the 12" maradyne fans. Much much better then the spial. I run 2 of these myself in the evo
http://www.maradynehp.com/products/champion/m122.php
Old Dec 14, 2011 | 08:57 AM
bnr34rb26dett's Avatar
fyi
https://www.evolutionm.net/forums/ev...-you-have.html
Old Dec 14, 2011 | 09:23 AM
CurseDSM's Avatar
Originally Posted by bnr34rb26dett
Eh I don't buy into that ****. Common since says thicker rad, more cores, more coolant inside makes more cooling compacity. Throw the fans on there your good to go.
Old Dec 14, 2011 | 09:51 AM
catman78's Avatar
stock radiator
Old Dec 14, 2011 | 10:02 AM
CurseDSM's Avatar
Originally Posted by catman78
stock radiator
That is the point i was making. I have a stock rad. The amount of heat that those fans will take out of the system is bennfical. I mean all the technical crap looks good on paper but its not about whats on paper its whats about in your car. I argue with archatecs all the time on this crap out in the field being I am a builder. They say oh well you can do it this way and get pissed off when you hand them your hammer and tell them go ahead try to make it work.
Old Dec 14, 2011 | 10:35 AM
catman78's Avatar
And your fans are how much slimmer then the stock ones?
My concern is space using the ETS kit and PTE.
Old Dec 22, 2011 | 10:18 AM
2000max's Avatar
http://www.streettunedmotorsports.com/parts/fal_fan.htm
I run this fan with my custom v-band turbo kit. Having a shroud was important to me. It's tight with my 4" intake but it definently fits. I'm unsure how much space you will get with some of the other kits on the market.
Old Dec 22, 2011 | 10:49 AM
CurseDSM's Avatar
I didn't see this post so my bad for not replying. The fans are only 3 1/8 thick.
Old Dec 22, 2011 | 11:05 AM
211Ratsbud's Avatar
This x 100.
Anyone run no fans at all with aluminium rad?
Old Dec 22, 2011 | 02:06 PM
catman78's Avatar
ETS sells a slim fan for $60 shipped.
I'm assuming it works with their kit.
Balrok
Oct 23, 2015 05:36 AM
mitsubeastlee
Sep 23, 2013 03:05 PM
02-Lancer-Es
Feb 6, 2011 10:53 PM
AutoMotoSports
Oct 6, 2008 07:53 AM
kungfugirl
Lancer Engine Tech
10
Nov 25, 2007 06:44 PM
