Eye Candy - look:-)
Old Jan 13, 2004 | 04:36 PM
Boost Solutions's Avatar
Talking Eye Candy - look:-)
Check that setup guys:
- BJs intake manifold
- Bosch 1650cc injectors
- NX Direct Port nitrous setup
It will be in the car tomorrow
Old Jan 13, 2004 | 04:45 PM
metaphysical's Avatar
Registered User
OMG...
By the way... I saw Sound Performance was talking about using the AEM and a direct-port dry nitrous system. Stating that the fuel systems in the nitrous kits are more prone to clogging, not as accurate etc. So utilize the regular injectors to provide the extra fuel based upon your nitrous map. Any idea or thoughts?
IILANCERII02's Avatar
no need for words
Old Jan 13, 2004 | 04:49 PM
Kaisho99's Avatar
Originally posted by IILANCERII02
no need for words
But a need for pics....they're not showing
Old Jan 13, 2004 | 06:03 PM
nonmature's Avatar
damn it I need to stop drinkin so much so mine can look like that.... mine thats goin in is just a plain jane NX wet kit
-non
Old Jan 13, 2004 | 06:19 PM
MYEVOVIII's Avatar
Damn George it looks so sweet. I might come by tomorrow after work just to see it. Plus I need to pick up that Forge Dv that I left up there the other day that Ryan tried on his car. I give you a call tomorrow.
Old Jan 13, 2004 | 06:33 PM
tom@kartboy's Avatar
looks nice
i'd shorten up the hardlines on the fuel side. the N2O will get to the nozzle a lot faster than the Fuel will and cause a split second lean situation. Just a thought
i've done more 2,3 stage systems for the big NMCA cars. that was a big prob with them
also have they flow'd the setup to make sure each side was spraying the right amount? its really easy to do off the car.
get a fuel pump plummed to the inlet.
run 4 beakers,one to each of the outlets of the jets. then do a timed running of the fuel side. read each beaker to make sure that your getting the right amount of fuel to each hole
FIRE IN THE HOLE!!!
good luck
tom
Old Jan 13, 2004 | 06:35 PM
bobaab's Avatar
good times ahead!
Old Jan 13, 2004 | 06:52 PM
Deceit's Avatar
damn george, you better put a garbage can in your car for the passengers when you're done with it. That Evo is a sure-fire vomit machine!!
Old Jan 13, 2004 | 06:57 PM
en1gma19's Avatar
Damn George, dan't wait until Friday so I can see it all in person. Came a long way since I was last down there. By the way, did you guys have that fuel pump in stock, or will you have it by Friday? Thanks
Chad
Old Jan 13, 2004 | 08:40 PM
Fourdoor's Avatar
1650cc injectors? Let me take a wild assed guess here.... Alcohol fueled?
Keith
Old Jan 13, 2004 | 09:05 PM
MrBonus's Avatar
Do you think you'll break into the 12s?
Old Jan 13, 2004 | 09:12 PM
BadBoyBeltran's Avatar
12s? We should be looking at at least low 11s for their set-up. 10s is not impossible either. Have you seen the turbo in their car?
Old Jan 13, 2004 | 09:19 PM
Stupid PC
Old Jan 14, 2004 | 12:03 AM
GotBoost25psi's Avatar
im wanting something closer to 9's
