fuel pump wire with high/low voltage circuit
Old Oct 19, 2012 | 03:13 PM
  #46
LeXcite's Avatar
Subscribed ...
Is there any news?
Old Dec 22, 2012 | 02:29 AM
  #47
EvocentriK's Avatar
Ive upgraded just my earth wire with 12AWG wire to a bolt under the back seat, got me another 500rpm until my injectors go static.
Any idea what the effect of replacing the wire from solenoid 3 to the pump with 10-12AWG wire would be? Might be worth a few points of a volt yeah?
Old Dec 22, 2012 | 10:19 PM
  #48
mrfred's Avatar
Maybe.
Old Dec 23, 2012 | 02:30 AM
  #49
EvocentriK's Avatar
Did it. Gained a few AFR points but not much more before they hit 100% IDC. I think I have to accept that I'm out of pump unless I'm prepared to wire up a direct line to the battery (I'm not). Might try a walbro 416 and see how that goes.....
Old Dec 23, 2012 | 09:14 AM
  #50
mrfred's Avatar
The Walbro 416 is way better.
Old Dec 23, 2012 | 09:21 AM
  #51
jameswwt's Avatar
Just wonder will it be better to direct wire the fuel pump with the battery?
My recent experience is my fp wires were extremely hot and to my surprise, its started to brittle.
Ive just changed the brittle part and add more grounding (if i could get it right) and im surprise again that me fuel pressure suddenly surge and the car run smoother but it just last for a week and is still hot.
What is the better way to solve this problem?
Ive added relay too.
Old Dec 23, 2012 | 04:48 PM
  #52
EvocentriK's Avatar
Are you saying your stock wiring is getting hot and becoming brittle or is it an after market hardwire kit?
Excessive heat is due to high current draw through the wire, some are rated quite high in temp but you don't want to run with super hot wiring. My stock wiring doesn't feel more than body temp running a DW301.
Old Dec 23, 2012 | 07:20 PM
  #53
jameswwt's Avatar
Hi Evocentrik, no its not stock wires and even after the change i think its not high temp wire. The wire is extreme hot after some hard runs.
Should i use a high temp wire and is there any which suitable for car? Its seem rare on my place here and we usually cut and take frm the halfcut engine wires. We will go for the biggest wire.
Old Dec 23, 2012 | 08:34 PM
  #54
jameswwt's Avatar
Is there a way to lower the wire heat?
Thanks
Old Dec 23, 2012 | 08:53 PM
  #55
joseph143's Avatar
Gonna do this sub
Old Dec 23, 2012 | 09:03 PM
  #56
EvocentriK's Avatar
Use larger gauge wire will make it handle higher current better. What pump are you running?
I have upgraded the stock earth and wiring from pump to fuse box leaving the stock relays and stock battery to relay wiring in place and I'm getting 12.75v at the pump in high voltage mode. I've heard people mention 12.3-12.5v at the pump on factory wiring.....and Mr Fred you were getting 12.9 on your custom dual voltage rewire setup.
Given that voltage seems my DW301 is flowing less than it should, seems to only be able to supply ~222LPH @ 12.75v @ 54psi (deliberately tapered boost to 19 psi up top and assuming ~35psi rail pressure). Max power at 105-110% IDC is ~440hp DJ on E85.
Originally Posted by BluEVOIX
for what its worth I did check the factory lines for voltage (multimeter) running to the pump and it was 12.5 volts. And I checked it by using a multimeter on the power wire to the fuel pump and "ground".
Old Dec 24, 2012 | 08:00 AM
  #57
jameswwt's Avatar
Im running on a 340L Aeromotive pump.
Mind to share the wire diagram direct tapping frm the battery to the fuel pump and earthing?
Old Dec 24, 2012 | 08:01 AM
  #58
jameswwt's Avatar
Have a fun filled blessed Christmas Dear Members...
Old Dec 24, 2012 | 08:27 AM
  #59
EvocentriK's Avatar
It's not a full rewire, it's 'improved stock wiring' I just traced the stock power wire from the fuel pump back to the fuse box under the drivers side dash (right hand drive - JDM model) and replaced it with 12 AWG wire (heavier gauge wire for lower resistance and bypassing 3 connectors). Cut stock earth off at the fuel pump plug and re-wired with 12 AWG to point under back seat.
MrFreds full rewire is what you want if you want to redo it all using new wiring from battery + new relays. Those aeromotive pumps pull a lot of current.
Old Dec 25, 2012 | 06:42 AM
  #60
jameswwt's Avatar
Thanks Evocentrik
