fuel pump wire with high/low voltage circuit
Old Jan 20, 2022 | 12:48 PM
  #376
vmrevo9's Avatar
Veteran: Air Force
Actually, some relays come with a flyback diode on the coil, and it does matter greatly which way these are wired.
you are correct! In most instances especially with kits like the STM version. The relays do not come that way from what I have seen
Old Jan 20, 2022 | 12:51 PM
  #377
Evo9isLife's Avatar
5 Year Member
So 85 to ground and 86 to hobbs NO terminal as most of the diagrams here show? , or 86 to ground and 85 to hobbs NO. Im assuming the color of the wire doesnt matter as long as its attached to the right connection/ground.
Old Jan 20, 2022 | 01:02 PM
  #378
Biggiesacks's Avatar
I'm sure you're right. Protected relays aren't nearly as common. I've blown one up before, so I felt compelled to be pedantic.
No idea for your exact hardware, but what I can tell you is the best place to find out is the data sheet. Google the part number on the relay, and I'm sure you will find what you're looking for.
Old Jul 16, 2024 | 05:28 AM
  #379
Gods_Pleasure's Avatar
Okay I know I'm about to be the millionth person who has brought this thread back from the dead but I was wondering if there wasn't some kind of device that can receive signal from the OEM power wire then use it to control the voltage supplied to the pump through a hard wire kit. I think this is similar to what previous users were saying about using resistor packs to lower the voltage of the hardwire kit in combination with relays but I wonder why there isn't a singular aftermarket solution to this. I know the Hobbs switch is standardized practice but if it possible to control it directly from the ECU then that seems like the superior method to me. Also does anyone know why this radium switch is so expensive? https://www.radiumauto.com/Adjustabl...itch-P921.aspx
Old Jul 16, 2024 | 06:23 AM
  #380
schuhie's Avatar
You can wire it up that way with a relay if I understand what you are asking for? Just use the OEM voltage to trigger a relay for the full battery voltage.
Old Jul 16, 2024 | 06:52 AM
  #381
LetsGetThisDone's Avatar
There's a lot more wiring involved, but you can use the ECU to control the "rewire" relay. I did it on my car, it wasn't straight forward. The "switch" is normal closed and makes the pump run with key off. So you have to wire that relay to a key power source. Or something, I don't recall exactly. It's just more work than doing a Hobbs switch and not really worth it.
Old Jul 16, 2024 | 08:25 AM
  #382
In that case is the potential for the Hobbs switch failure that I constantly hear about realistic? Or is it over exaggerated? Also any comment on the 90 dollar switch by radium?
Old Jul 16, 2024 | 06:41 PM
  #383
The Hobbs switch failing has the same likelihood of a relay failing, so that's not really an argument for or against it.
That radium switch looks like a stainless Motorsports grade switch. Not sure who makes it, but the MAP and pressure sensors that look like that are $200. So it tracks with that.
Old Jul 16, 2024 | 09:29 PM
  #384
Okay makes sense, appreciate it man.
Jaraxle
57
Jun 5, 2023 07:45 PM
sabastian458
34
Nov 14, 2011 12:56 PM
utripin
Sep 27, 2011 12:56 PM
Acree
Sep 2, 2010 01:57 PM
Knyght
Apr 20, 2005 04:02 AM
