walbro 400lph no pressure
Old Dec 27, 2011, 12:07 PM
acssa's Avatar
I just installed a walbro 400lph and there is no fuel pressure...
I can hear the pump running but no pressure.
I checked that the red wire on the plug goes to +....
Old Dec 27, 2011, 12:24 PM
evolutionxtac's Avatar
You need to check where the fuel pump is seated. The black rubber grommet that goes on the fuel pump is not inserted or seated properly. I found I had to modify the plastic collar to fit on the neck of the fuel pump and then insert the rubber grommet. Otherwise without the plastic collar, the rubber gromment will be prone to coming loose, thereby resulting in very low fuel pressure.
Old Dec 27, 2011, 12:38 PM
acssa's Avatar
solved
Ckeesee12
Sep 13, 2016 12:13 PM
magnex265
Aug 7, 2015 09:24 AM
ChrisCarey
Oct 24, 2011 04:02 PM
racer135
10
Feb 24, 2008 05:57 PM
93civEJ1
Jun 30, 2004 09:44 AM
Quick Reply: walbro 400lph no pressure
