We need a HTA3586 vs 6266 comparison!
Old Jan 8, 2012 | 12:08 PM
ScorpionT's Avatar
Originally Posted by evo4nr
What about the new 6262 CEA that looks on paper the best option? Quicker Spool + More Power.
HTA86 and "old" 6262 with the right options were Very Similar and i can't see why a 6266 would be worth having as how much more power can you squeeze from a 62mm wheel, i always thought the 6265 was deemed a flop?
I want to see some tangible evidence of the new 62mm turbine being so much better. I have seen the photos and while the blades are thinner having less mass, the design appears to be the same which would mean no changes in efficiency or mass flow capability.
The 6265 has its place with larger displacements or higher flowing heads. A couple examples would be a Supra or S2000, where the larger turbine would beneficial.
Originally Posted by evodan2004
How about a pte 6266 sent to fp to have the Hta86 comp wheel put on it. Now you have s turbo with newer turbine technology with the killer Hta comp wheel. Anyone think that will work
It could be done, the shaft size is the same as the 35R turbine I believe. However, the UHP turbine from the 35R was a fair amount better than that of the 6262, and stepping up to the 66mm may not be necessary (overkill).
Originally Posted by Sharkbite2000
I love the power PTE makes but I hate that the turbo's die very fast , I went through 5 or 6 of them in a 3 month period they just dont last long especially running high boost.
Thats what happens when you beat the snot out of them everyday Nobody can say you dont use the horsepower you have available, thats for sure.
Old Apr 28, 2012 | 05:05 AM
foxbear2277's Avatar
After reading this, im pretty happy I went with the 3586
Old Apr 28, 2012 | 05:25 AM
SmurfZilla's Avatar
NO one has done a direct comparison of a HTA86 vs a 6266 or 6466. All we have are some very intelligent opinions.
Old May 23, 2012 | 12:00 PM
4G63 T's Avatar
bump for some more info
Old May 23, 2012 | 01:27 PM
4ukc's Avatar
I am using 6262CEA ATM and I had FP3582 I can say 6262 is a step ahead
Old May 23, 2012 | 01:41 PM
Josh@Spec-Ops's Avatar
The 6266 will allow a faster spool over the 6262 the 6466 will be laggier.
Old May 23, 2012 | 03:00 PM
Migsubishi's Avatar
Old Mar 16, 2013 | 10:13 PM
joeyhauser's Avatar
Tell us something that we don't already know.
Old Mar 16, 2013 | 10:39 PM
riceball777's Avatar
I have the fp htagt 3582r currently with 80,000 on this turbo and setup with 0 problems.
Old Mar 16, 2013 | 11:24 PM
Piro Fyre's Avatar
Originally Posted by n2oiroc
i cant remember the last time i heard of a ball bearing fp failure, its all the journal bearings that are failing. the hta86 should be very reliable.
I don't know if you're part of the Wisconsin Evo Owners on Facebook but there was a guy on there just recently (maybe a couple hours ago) that had to send his brand new FP Red in because of a bent shaft. He ordered it directly from FP too.
And just like any other Garrett and Garrett based turbos, they last longer than what Precision has to offer. Of course, don't run it max boost all the time and you might get more miles off of it.
Old Mar 17, 2013 | 08:42 AM
joeyhauser's Avatar
So as far as spool and power, what is the better buy?
Hta3586
Pte6262cea
Pte6266cea?
And for the results I have seen on the 6466, that sounds like the best option out of them all. It spools pretty damn good for the size, and makes 900+hp. I think the evo x with 908whp hits full boost by something like 4200 on a built 2.0. That's insane.
Old Mar 17, 2013 | 10:30 AM
Steven's Avatar
Hta3586
Pte6262cea
Pte6266cea?
I ended up going with the 6466 and have no regrets. I hit over 40psi around 5200 rpm and hold it to redline. I have made over 800hp so far and am not finished tuning. Hoping to hit 850-900 at 50psi.
Old Mar 17, 2013 | 10:50 AM
joeyhauser's Avatar
That turbo should be a 900+ turbo. There is an evo x that made 908 at (I think) 43 psi. You should be able to make more power and not have to have such high boost levels.
Old Mar 17, 2013 | 05:12 PM
Steven's Avatar
I was running S2 cams and still running rich with moderate timing. I've upgraded to S3s and will finish the tune pretty soon. I ran across a closed loop issue that took me a little while to figure out. Hopefully in the next week or two, I'll be able to get on it again.
Old Mar 18, 2013 | 09:26 AM
Michael @ FP's Avatar
Curious, could you link me please?
How could someone know it's a bent shaft if it hasn't even been inspected yet?
-Michael
