ACD light turned off / ABS light turned on
Old Dec 28, 2011 | 06:39 AM
williams12's Avatar
Hello:
My car was stopped for months when I went to boot was without battery. I used a cable with another battery to engine start. When I start the engine, i saw that the acd light turned off and ABS light turned On.
I did the following tests:
- ABS ecu new
- ACD ecu new
- Fuses
- Relays
Does not solve the problem, I did a check of voltage to the ecu and do not reach the 12 + . I put a cable from the + battery to the pin of the ACD ECU. The Light ACD turned " ON " but the abs light is turned ON.
Check all fuses including those of the terminals of the battery and nothing. There is no voltage to the ACD ECU in original wire car.
any solution?
Regards.
Old Apr 24, 2012 | 06:09 PM
andrewzaragoza's Avatar
did you find the solution to this
Old Jul 10, 2012 | 05:07 PM
Evoardo IX's Avatar
I had this same problem, acd light off, abs light on, it turned out to be a 7.5 fuse inside the car, so if you have this problem check all fuses in the cabin, I replaced that little fuse and everything went back to normal.
Mitsu.kid.02
Lancer Engine Tech
10
Dec 24, 2020 10:27 AM
DarkEvo
18
Oct 12, 2015 07:54 PM
Randal
Jan 30, 2013 05:50 PM
bboy_RES
11
Jul 17, 2010 05:06 PM
panda007
Dec 28, 2009 11:58 PM
