Higher fuel pressure cons
Old Dec 28, 2011 | 12:09 PM
acssa's Avatar
What are the cons on running 50-55 psi fuel pressure?
Old Dec 28, 2011 | 12:42 PM
Spec-Ops1's Avatar
I didn't really witness any ill effects while running 55psi base in my car... It ran this base FP after rewiring a single walbro 255...
Old Jan 3, 2012 | 08:56 AM
mrfred's Avatar
No cons, but if you are intentionally trying to run higher pressure, you may find that it does not provide any additional fuel because pump fuel flow decreases as fuel pressure goes up. depends on the pump setup and boost level.
Old Jan 3, 2012 | 09:51 AM
240Z TwinTurbo's Avatar
you need to determine the ultimate boost you want to run and then add that to the base pressure. So, if you want to run 30psi then you would need to see how the pump will flow at 85psi (55psi + 30psi). Pump flow decreases with an increase in pressure so be mindful of this. If you are starting from scratch and have to retune regardless then set the base pressure to ~43psi, which gives you a total pressure of 73psi. You will get much more flow from your pump at 73psi vs. 85psi.
Jovan Caro
Feb 6, 2017 08:03 PM
m7mad.a
Mar 4, 2012 05:33 AM
dubbleugly01
Dec 6, 2009 07:33 AM
EvODavO
13
Feb 28, 2009 04:09 PM
GreedMOTO
18
Oct 29, 2006 12:10 PM
