Very Unusual Noise at High Speed - Please Diagnose
o...... well if there was heavy wind then ya no wonder. thats not abnormal to experience going 100mph into heavy wind. its just pushing its way past the window seal and making a loud whistle hissing noise. nothing to worry about
as far as fluids go, i use OEM in tcase and rear and wouldn't recommend any diff. but that's me.
i'd agree but i got too many recommendations from other shops to stick with diaqueen.
fwiw i think i will go back to svg gear for the t-case, but i think the rear differential simply just prefers the straight 90 dino oil.. something to do with actually having less additives, which the diff doesnt make as much use of
I am not saying you are wrong, but I have seen way too many evos running SVG in the rear diff and tcase with great results, additives in the oil is a known good thing to have in the system, it greatlly helps with keeping stuff clean and shear stability where dyno oils don't have this capacity
You know where I am coming from this has been shown through test time over and over again here in the forums.
I think the noise issue is more or less diagnosed - thanks guys!
kyoo
92
Feb 25, 2019 07:16 AM
