bad clutch or tranny :/
Old Dec 30, 2011 | 10:24 PM
evo8kg's Avatar
Its hard to go into first and reverse. u have to force it. could this be the clutch or tranny? it has a stage 2 clutch
Old Dec 31, 2011 | 02:41 AM
Chaser_41's Avatar
It could be either probably... How many miles on clutch ?
Old Dec 31, 2011 | 06:21 AM
cfdfireman1's Avatar
does it matter if it's cold or hot? running or off make a difference?
Old Dec 31, 2011 | 08:24 AM
javicracer's Avatar
5 speed or 6?!?!?
Old Dec 31, 2011 | 08:51 AM
evo8kg's Avatar
i dont know how many miles are on the clutch. car hasnt been driven for about 2 and a half months. supposably it was fine before. i didnt drive it much. just up and down the street. once i got moving it got better. its a 5 speed
when the car is off it goes perfectley into all gears
Old Dec 31, 2011 | 09:21 AM
fasolxpl's Avatar
i had the same issue.. before u do anything adjust the clutch pedal.. sometimes if the clutch doesnt engage right it seems like gears go in weird.. i had the same issue on my 6speed. just adjust the clutch pedal and see if it helps
Old Dec 31, 2011 | 10:47 AM
evo8kg's Avatar
!ill try that and hope thats it. thanks1
Old Dec 31, 2011 | 12:38 PM
If the clutch adjust doesn't do it a trans fluid change should.
Old Dec 31, 2011 | 12:57 PM
kimma's Avatar
see if the plastic bushing is cocked under gear selector on the tranny..looks like a half moon.oh and good luck
Old Dec 31, 2011 | 02:28 PM
Hendrixmx's Avatar
you could try bleeding your clutch
06redrocket
Mar 22, 2010 06:14 PM
RedlineX79
64
Jul 27, 2009 08:48 PM
JuanBond
Lancer Troubleshooting
Jul 17, 2008 11:47 AM
blackep925
Feb 9, 2008 02:56 PM
dryad001
62
Mar 2, 2007 04:45 PM
