Evo 4 Ecu Flash???
Old Jan 3, 2012 | 03:50 AM
jameswwt's Avatar
Evo 4 Ecu Flash???
Hi Guys,
ive bought an Evo 6 ecu and planning to ecu flash it but only noticed there is no port for the OBD II cable.
Does Evo 4 wire harness comes with the OBD II port?
Thanks
Old Jan 3, 2012 | 04:25 AM
SaulHudson's Avatar
I don't really understand what you are asking. There is a OBD II port in the IV's if that is what you are asking.
Old Jan 3, 2012 | 04:37 AM
jameswwt's Avatar
Hi, sorry for the noob question as im not a tech guy but what wire port do a Evo 4 need in order for the Ecu Flash port to tap onto it?
Old Jan 3, 2012 | 10:59 AM
jameswwt's Avatar
Anyone???
Old Jan 9, 2012 | 07:40 AM
Mauricio Evo IV's Avatar
Originally Posted by jameswwt
Anyone???
You only need to change the some pins in the harness...
Conecct the Evo 6 ecu and done! i have in my evo an Evo 8 ecu and works fine. you can use only with that OBDII cable (Tactrix cable or scanner)
Old Jan 9, 2012 | 12:54 PM
jameswwt's Avatar
Thanks Man...+1
Old Jan 9, 2012 | 08:52 PM
jameswwt's Avatar
Hi, im new to ecu flash and can someone here show me where should i download the latest ceddy software for flashing Evo 6 Cp9A ecu?
Lastly, how to activate the ALS and can it be activated/control manually with a switch?
As not planning to go for a full time ALS while on street.
Thanks
Old Jan 9, 2012 | 11:40 PM
grayw's Avatar
You need to add a wire to pin 79 on the ECU for flashing, the IV does not have one.
Old Jan 10, 2012 | 03:13 AM
jameswwt's Avatar
Thanks Grayw,
btw, do the ecu flash activate the ALS and can it be activated/control manually with a switch?
As im not planning to go for a full time ALS while on street.
Thanks
Old Jan 10, 2012 | 04:48 AM
grayw's Avatar
The SAS is activated in the rom and is not switchable. Maps are switchable, same as the tephra roms.
Old Jan 10, 2012 | 10:09 AM
jameswwt's Avatar
Oic...
Old Jan 11, 2012 | 07:09 AM
Thanks Grayw,
Thanks
If you want ALS you can retard timing for that. Like this:
https://www.evolutionm.net/forums/4977640-post22.html
althemean
21
Oct 24, 2015 12:26 PM
toxic-evo
Jul 24, 2015 07:42 AM
FASTER345
Feb 18, 2015 08:08 AM
black_out
May 6, 2014 12:09 PM
tephra
60
Apr 17, 2012 09:34 PM
