Let's see your fully tuned timing maps
Old Nov 20, 2007 | 12:42 PM
EvoBroMA's Avatar
Originally Posted by dudical26
12psi off the two step instead of 6-7 like stock.
some people also do this to combat knock - for those that don't set all the octane maps the same.
Old Nov 20, 2007 | 03:47 PM
C6C6CH3vo's Avatar
It is very interesting the ethanol fuel allows with timing. Has something to do with the flame propagation stability regarding pressure (beyond the scope of my knowledge), about every ethanol timing map shows 16+º by 6000 RPM.
Old Nov 20, 2007 | 11:41 PM
lemmonhead's Avatar
why is everyone posting map#1,
map#2 is the base map, or are you guys putting both maps the same?
also I agree with 25 or higher boost you need to cut back that timing. seems to much for me.
Old Nov 21, 2007 | 02:42 AM
recompile's Avatar
If you do not set all 3 maps the same, you will not have reliable numbers... the ECU uses a combination of all 3 to get the actual timing used, an no one knows the exact reason for having 3 maps, other than the fact that you need to set them all the same in order to have a repeatable tune
Old Nov 21, 2007 | 03:03 AM
Dnealy's Avatar
lol shouldnt there be some kind of disclaimer on this thread. So someone who doesnt understand that all cars arent the same doesnt just throw one of the maps on and go boom.
On and it someone will(yeah i know im the dumbest person on here when it comes to comps) tell me how to get just my timing map up ill be more than hapy to post mine before my s1s and after.
Old Nov 21, 2007 | 03:06 AM
recompile's Avatar
Bring up your map and hold ALT and hit PRTSCN
Now Start > Run > mspaint
Hit CTRL + V to paste it in. Save it as a JPEG. Upload and you're done!
Old Nov 21, 2007 | 05:19 AM
TouringBubble's Avatar
Here is my current winter map ...
EDIT :: 93 oct, IX
Honestly guys, I've wanted a car that shot flames for years so I simply had to do it. It's also a nice intimidation method at the track.
(yes, I know that timing only goes to -10)
Old Nov 21, 2007 | 05:23 AM
inco9nito99's Avatar
^^ lol that made me chuckle. how much boost are you building with the 6-8degree block?
Old Nov 21, 2007 | 05:47 AM
It was at 6-7-8 and I was building about 12 psi on the line. It's probably closer to 9.5 or 10 psi with 6-8-8 ... I honestly haven't checked. I changed it last time at the track to reduce wheel spin.
Old Nov 21, 2007 | 07:23 AM
Nuked's Avatar
My pump gas timing map.
SQ
Old Nov 21, 2007 | 07:25 AM
Nuked's Avatar
EDIT :: 93 oct, IX
I have played around with something similar. Never had a map sensor to get good data, but it seemed like it held boost between shifts a lil better. Downside is it gets a lil annoying on the ears after awhile! haha
SQ
Old Nov 21, 2007 | 07:26 AM
EvoBroMA's Avatar
yeah right? not sure if its just New England Dragway's terrible track prep - or maybe my crappy tires? but i don't know how some of you want more boost off the two step - i just spin and spin and spin... my best 60' is 1.8
also TouringBubble: you rule for admitting your a ricer. i find it hard to believe there isn't a little ricer in all of us who drive this car.
Old Nov 21, 2007 | 07:37 AM
I pull low 1.7's feathering 1st, but I've landed a 1.62 when it actually hooked. I've got the benefit of track temps down here, but it's a trade off for the insane humidity.
And it would be silly for me to try to make excuses for that retarded timing on lift off. I didn't do it to hold boost on shifts (I'm using the NLTS mod) ... all it does is shoot flames. And it is AWESOME.
Old Nov 21, 2007 | 08:53 AM
esevo's Avatar
Any side effects from the flames? any knocks?
Old Nov 21, 2007 | 08:55 AM
bnice01's Avatar
LOL i shot big flames all the time but I have meth
i'll try to post my timing map its meth, self ported 6 blade 20g, 30 psi spike holding 27-28 @ redline, trap 91-92 in the 1/8 running 7.5's, afr's are 11.8-11.4 @ shifting point
