Long rod 2.0 vs standard 2.0
^ haha I know but see I used "search" instead of starting a new thread
I've been curious about building up the engine with the 2.3 but it seems to have a longevity (with some) issue per all the people who build the engine and then sell them almost right after.
My goals are modest so a 2.0 LR seems to be the way though I've been reading the longer stroke puts extra stress on the bearings and pins
I just got done reading jacks transmissions info on balance shafts delete not being good so just trying to get my research done.
http://www.jackstransmissions.com/pa...balance-shafts
No balance shafts is fine with a good clutch.
And once again, building a 2.0lr is pointless. Only reason to use a longer is is if you run a 94mm crank you can use a 153mm rod in the 4g63 block.
Reaving the car is fun, when you can pull longer in the gears , 9500 PRM
chouse a crank , that have small nocks and match it whit the right rods , and you will make som good power ,
the other thing is a strocker enginge , but then you wont be able to rev that mutch ,
but then you will make power more easy whit a big turbo , precition 6262
Think that 800 hp is not cheap , you will need a lot of maintenss , a big fule system , intake , mainfold , indjectors pumps , enginge management , tune , IC , e.c.t
I dont wanna broke your dreams but 500 + is more driveable on the streets , and you will have more fun , and less headeck , and more use of your car
lmfao
But seriously nobody has talked about cylinder filling differences between a long rod and short rod motor. Yea yea everyone has regurgitated the piston side loading debate but the real reason a long rod revs so well is the cylinder filling is more efficient, along with better TDC dwell time at high rpm. The rod ratio is 1.70 stock and 156mm rod makes it a 1.77 ratio, not a huge difference but I’ll take what I can get. At 1000hp that’s probably good for 25hp, but hey that’s free power.
read this.......
https://www.team-integra.net/forum/b...latnships.html
I'm trying to learn to be less judgemental...but it's hard when the internet is full of people that read and write on a 2nd grade level. LOL
I can only take so much. I had to leave a Mopar group, on FB, because I just couldn't take it any more.
Sorry to be off topic, but this thread is had been dead for years, anyway.
now that’s some funny $hit right there!
lmfao
read this.......
PPTPerformance
Dec 14, 2017 02:10 PM
louiesevox
10
Oct 29, 2017 06:56 AM
FS[Northeast]: Evo acl rod bearings
talonkev
May 9, 2017 05:43 AM
Rutherford88
May 27, 2016 04:25 PM
