P0340 Cam Sensor Code Help
Old Aug 15, 2013 | 03:31 PM
michaelrc51's Avatar
Have the same for mine, throwing crank and cam sensor codes as well as 365 after it is running for a bit. I just got all new crank and cam sensors, going to put in the cam sensors and see before I install the crank position sensor.
Thought it wouldn't run with a crank sensor code but mine does run.
Old Aug 15, 2013 | 04:57 PM
ihockey1's Avatar
sorry i still havent had any breaks on whats causing my car to throw the codes and the issues that its having, ill update this when and if it gets fixed
Old Aug 15, 2013 | 06:14 PM
SmurfZilla's Avatar
I have been having this issue. Crank angle sensor replace, cam position sensor replaced on exhaust side i think. Spec-Ops has a intake cam sensor for me I will be going to get it replaced next week. I hope this fixes it. I have been tempted just to turn it off in the ECU but Spec-Ops advised against it.
Old Aug 15, 2013 | 08:01 PM
ihockey1's Avatar
let me know if it fixes your issue, so far ive replaced the intake cam sensor and the shop has gone through the wiring and replaced numerous burnt wires and tried another ecu but the issue is still there
Old Aug 15, 2013 | 08:04 PM
SmurfZilla's Avatar
I didn't think a different ecu would work
Old Aug 15, 2013 | 08:22 PM
ihockey1's Avatar
me neither just process of elimination to rule out the possibility of the short going back to the ecu, at this point no one has any idea whats up with my car so who knows when and if ill get any good news
Old Aug 16, 2013 | 03:09 PM
Make sure you check all the timing stuff..... Trigger wheel and cam pieces..... Just verify that they are all in the right orientation.
EDIT--I see you didn't even touch that stuff.....
Posted from Evolutionm.net App for Android
Old Aug 17, 2013 | 07:23 PM
Found my issue...the cam sensors were reversed.
Old Aug 19, 2013 | 06:14 AM
rgpleasant's Avatar
Correct me if im wrong, but i have an Evo VIII so i only have one cam sensor right, the Evo IX has the intake and exhaust cam sensor?
Old Sep 16, 2013 | 06:25 PM
ihockey1's Avatar
sorry just saw that, yes 8's have one sensor
ihockey1's Avatar
updated the op on page one
Old Sep 16, 2013 | 06:47 PM
90zcrex's Avatar
There are 3 wires on the cam sensor connectors, with the connector unplugged and looking at the pins with the connector lock on top, the pins are from from left to right 1,2,3. With the key in the on position, pin 1 should be a ground, pin 2 should be 5v, and pin 3 should be 12v. Check this on both intake and exhaust cam sensor connectors, if any of these have incorrect voltage is where your issue is.
Old Sep 17, 2013 | 12:37 PM
ihockey1's Avatar
ill have them check that thanks
Old Feb 19, 2020 | 01:03 PM
Nickelplz's Avatar
Was a fix for this found?
blackbelt
Mar 7, 2017 07:00 AM
LudaChrisLancer
Lancer Engine Tech
Feb 4, 2017 04:20 PM
LudaChrisLancer
Lancer How Tos / Installations
Feb 4, 2017 04:13 PM
okevolutionVIII
68
Jun 20, 2012 05:55 PM
