Pedal to the floor. HELP!
Old Jan 22, 2012 | 01:41 PM
meckert's Avatar
Pull the boot back on the slave and be sure the piston isn't stuck and lodged against the cylinder itself.
Old Jan 22, 2012 | 01:53 PM
thedru13's Avatar
I can move the fork and the slave piston. I moved the slave out of the way took a crowbar and tried to snap it back. Just won't clip in. When it happened I felt a pop ah the the bottom of te pedal.
Old Feb 5, 2012 | 03:57 PM
thedru13's Avatar
well figured out my issue... Pics of the carnage. TOB is trash..
Installed and Excedy Twin disk and wow what a difference...
Old Feb 5, 2012 | 04:04 PM
Most-Wanted's Avatar
Glad you figured it out. Sometimes its the flared fitting from the slave that cracks.
Old Feb 5, 2012 | 04:15 PM
thedru13's Avatar
yah I replaced everything. TOB, slave, Fork and put the STM stop in as well Didn't want to rule anything out
Old Feb 5, 2012 | 09:55 PM
tstevens's Avatar
D***! Glad you figured it out, had the same issue with my old STi when we did the new clutch. Pushed in the pedal and it popped and stuck on the ground. We eventually traced it back to needing the slave cylinder bled. The fork looked exactly like the picture you took, glad you fixed the issue though!
Old May 13, 2012 | 08:42 AM
bevolucion's Avatar
this just happened to my car last thursday, what a pain in the a$$. Now my tranny is off and waiting for the TOB to get here cus nobody carries it in stock around here. On topof that is my only car.
