hoot or whine from clutch?????? not TC
Old Jan 24, 2012 | 05:38 PM
costo23's Avatar
What I have noticed in the last few times I have driven my car is that when down changing from say 4 to 3 or 3 to 2 I sometimes (not everytime) get a noise coming from the gearbox or clutch. once the clutch is fully engaged the noise is gone but whilst the GB is coming up to speed it makes a kind or a whine or a hoooting sound ????? any clues as to whats going on???????
Old Jan 24, 2012 | 05:57 PM
ApexEVoIX03's Avatar
does it do it when you drive off in first?
and is it and exedy twin disc? if so My car makes the same noise and was told its normal
Old Jan 24, 2012 | 06:00 PM
costo23's Avatar
havent noticed it in first gear only when down changing mostly 3-2. I havent changed the clutch in it so not too sure what is in it...... doesnt feel like anything after market.
Old Jan 24, 2012 | 06:01 PM
damn.. then i'm no help. GL with finding out what the problem is
Old Jan 25, 2012 | 05:20 AM
blk2gdsm's Avatar
Figure out what clutching is in it...lay under the car, there will be a rubber plug on the bell housing of the trans. Pull the plug out and tell us what color the clutch is and what it looks like. My twin disc was noisy as hell
Old Jan 25, 2012 | 05:56 AM
Evo8MR569's Avatar
i have the same problem, but with mine the sound gets louder as i go faster... not the tc because i just had it rebuilt by shephard... i have a act clutch xtss .... i heard that it could be the input shaft bearing..
Old Jan 25, 2012 | 06:11 AM
blk2gdsm's Avatar
Possible...I'm runnin the same clutch as you evo8mr...I get a whine only in first gear...that's usually the only time it makes noise, the only way to find out if the input shaft bearing is going bad is to pull the trans
Old Jan 26, 2012 | 10:07 PM
costo23's Avatar
Yeah not that keen on pulling the gearbox. Maybe have to wait till the problem becomes more pronounced. Just like to know what it is that's all. It not easily repeated only happened once on the way home from work. But by the feeling i would say you sounds like a bearing.... Is there an input and output shaft bearing???? It's not in a single gear so it's got to be something that's constantly rotating
Old Jan 26, 2012 | 10:09 PM
costo23's Avatar
Will try to get under and have a look at the clutch also...
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
ablan029
Dec 17, 2013 04:35 PM
Imprezme
Mar 21, 2013 07:53 PM
hillbilly8R
Aug 24, 2008 12:45 AM
rallyevo8
18
Apr 23, 2007 03:30 PM
