Possible bad synchros
How is mitsu handeling synchro problems lately. I have a bad grind in 2nd and 3rd gear. I also can't get it in 2nd at times. I had my clutch replaced at 2600 miles. When they did it I asked if everything else was ok, they said yes. When I got the car back it felt like the clutch engagement was much lower and I had both grinds which at 6k have gotten worse.
Before you make any menacing comments, My car has not been abused at all. I drive spiritidly, but I do not launch nor do I bang gears.
Are these being covered by warranty
if it's bad synchro then it will be covered.
try changing your transmission oil, some ppl did this and have smoother shifting.
i had a 5th gear synchro problem and took it in for 3 weeks. covered by warranty
This gear grinding has been discussed many times..
i believe the post is here..
grind into second
Also, do a search..
The car has grind/Synro issues that kind of come and go I guess..
grind into second
Also, do a search..
I just got a grinding noise into this week. I have redline fluid. Just started after 8k miles. Only does it sometimes. Gunna have mtisu take a look. Hope they dont ***** for all my mods. We shall see.
I was informed today by my stupid *** dealer that they don't cover synchros because any problems would have been caused by the clutch, and they don't cover anything that deals with the clutch. what next the trany is connected too so its not covered, and because that touches somthing else its not covered, eventually the whole car will be non warranty work.
mitsu is the worst company I have ever dealt with, and will never buy from again. soley based on customer service.
Bring it to a different dealership
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
I had a bad 4rd gear syncro and the dealer didn't give me any problems. They rebuilt the transmission under warranty and were very good about it. I also paid to have the clutch replaced, just the parts, they took care of the labor. I had 8700 miles on it when this happened. Also ended up replacing the 3rd gear and a few other parts.
If you would like, PM me and I will fax you a copy of the work order showing that it was taken care of under warranty.
Good luck
Good luck
CaptainSquirts
10
Jul 15, 2015 11:51 AM
stunt2
Dec 29, 2011 05:32 AM
