Havin a oil leak prob....ned help
Old Jan 28, 2012 | 07:34 PM
MaDD-Myke's Avatar
Im having an oil leak which i believes is come from the head gasket but i had different people looked at it and they said its not my head gasket,if it aint smoking,over heating and lagging.....but the guy who i bought the car from said the #4 cylinder is reading at 85 and the other 3 is reading at 160. So i cant tell where this oil leak is coming from.it only leaks over night on my drive way....any inputs on this lil prob
Old Jan 28, 2012 | 09:42 PM
Jerry321's Avatar
If it was a headgasket you'd be leaking coolant, hence the white smoke from exhaust.
Clean every drop of oil including undercarriage then let it sit overnight like you said it leaks, then check again, it'll be easier to spot.
Old Jan 28, 2012 | 09:44 PM
Jerry321's Avatar
So a leakdown test, that compression number is too low.
Old Jan 28, 2012 | 11:41 PM
Lazyfong's Avatar
Get a bottle of uv dye and uv light, it will help you trace where the oil is coming from.
http://www.amazon.com/Tracerline-Dye...ef=pd_sim_hi_1
JamesKrickeberg
34
Apr 29, 2020 07:16 PM
EVOEvolved
Aug 19, 2016 06:13 PM
Deano_Engineer_
May 24, 2013 11:10 PM
REDEVO1113
13
Nov 2, 2012 10:40 AM
EVIL-EVO-8
29
Jan 21, 2011 05:43 PM
