AEM EMS to Stock ECU SD
Old Jan 29, 2012 | 12:15 PM
Blue91lx's Avatar
After sorting through information and just doing the swap, it turned out to be easy.
Honestly, the Stock ECU is great. I have noticed NO ill side effects, and it is a ton easier to tune than the EMS.
All I did for the swap was:
-Replace AEM 5 Bar with Omni 4 Bar
-Replace 11 tooth crank trigger wheel with OEM crank trigger wheel
-Replace modified cam trigger wheel with OEM cam trigger wheel
-Plug factory harness into Stock ECU!
So, there's a black and white "what you need to change" for anyone else who stumbles upon this thread.
Old Jan 29, 2012 | 03:43 PM
211Ratsbud's Avatar
Pnp aem or cutting harnesses aem?
Old Jan 29, 2012 | 03:50 PM
Blue91lx's Avatar
Sorry, Plug and Play.
Old Jan 29, 2012 | 05:36 PM
marrrk's Avatar
i would be really interested in your reactions, going back to stock and sd in com parison to your aem. i have been on an aem like almost 5 yrs, i just switch back to the stock ecu and go thru, and change right back, or should i say the man that tunes my car takes car of it.
Old Jan 29, 2012 | 10:14 PM
Blue91lx's Avatar
Haha I'm interested in my reactions as well. However, I need answers in order to perform the change.
Old Jan 29, 2012 | 10:25 PM
211Ratsbud's Avatar
SD on the stock ecu requires a map sensor, fuel temp or air temp. Thats all. Any map sensor and pretty much either method of acquiring a temp reading does the trick... take a look at your engine bay if theres an aftermarket ign system just make sure its stock ecu friendly. Look for other non stock sensors. Sd is very simple on the stock ecu.
Old Jan 29, 2012 | 10:29 PM
Blue91lx's Avatar
Thanks man. I have a MAP sensor already (JDM 3 Bar). I was just confused on what I keep from the AEM, as I obviously already have an IAT sensor.
Old Jan 29, 2012 | 10:31 PM
211Ratsbud's Avatar
Ninja edit fail.
Old Jan 29, 2012 | 10:46 PM
Blue91lx's Avatar
Hahaha. I quoted you before you could be stealthy.
My main question was just about which sensors are specifically for AEM, and which sensors were stock.
I have an IAT on the UICP and I have a Coolant Temp sensor on the block. I don't have a knock sensor, but we tune with a stethoscope to work around that, and I obviously have my crank and cam sensors. Anything I'm missing? Boost is controlled manually. I suppose I should be good to go then. Would I have the ability to unplug the EMS and plug the harness right into the Stock ECU, or do I have to re-wire everything into a different "plug" to fit the stock ECU?
Old Jan 31, 2012 | 05:30 PM
Blue91lx's Avatar
Does anyone know if AEM calls for the IAT to be spliced into the MAF harness like it should be for SD on the Stock ECU?
Old Mar 5, 2012 | 12:48 PM
Blue91lx's Avatar
Bump this from the dead. Will I need to get Mitsu sensors, or are the AEM sensors compliant with a stock ECU?
I'm confused as to why there's so little info out there on this subject.
Old Mar 5, 2012 | 01:15 PM
211Ratsbud's Avatar
The aem iat is compliant. You just change the ecu scale to match.
How do you have your iat wired now with aem? You can just use fuel temp to sim iat, its proven and works well.
Old Mar 5, 2012 | 01:30 PM
SmurfZilla's Avatar
No need to splice the IAT in with spoolin ups adapter harness.
Old Mar 5, 2012 | 02:55 PM
Blue91lx's Avatar
That's what I was planning on doing. I bought the car with AEM on it, so I'm not 100% sure how it's wired.
This is also good to know.
Thank you both, that clears a lot up.
Old Mar 6, 2012 | 08:12 AM
mrfred's Avatar
all sensors should be stock with the exception of the mat and map sensors. aem's mat sensor is likely a gm sensor so you'll need to rescale the iat sensor table for it. some tweaks are also needed for the map sensor.
