4g64 with lancershop wiseco stroker kit?
Hey EvoM!
I've been doing alot of reading about using 4g64's for a block and I want to try it.
AWD says they have 4g64 cores for around $500.
I see lancershop has a wiseco stroker kit for $1500.
so $2000 and I have a 2.4L? Anything need to be done to the 4g64 to handle that kit?
http://www.lancershop.com/customer/p...&cat=94&page=1
This is an Evo VIII I have.
Any other tips would be greatly appreciated.
Best Regards,
Jay.
Best Regards,
Jay.
Not what I'm saying at all, stroker pistons are 6mm shorter than standard pistons on 4G63 stroker builds. The 2.4L is not a stroker so don't get a stroker kit. A 100mm(factory 4G64) crank and non-stroker 86.5mm(factory 4G64 size) pistons are what you need unless the block need machining then go for .20 over(87mm) pistons.
dambikeracer
88
May 21, 2010 06:27 AM
