new clutch install, slave not pushing enough
Old Feb 3, 2012 | 06:24 PM
jacksons's Avatar
hey guys and girls
just brought a evo 8 and had to change the clutch already
unlucky i guess but what can u do
anyways i brought myself a single plate carbonetic clutch kit with the push pull conversion kit
problem is that the slave cyclinder is not pushing enough to disengage the clutch so i cant put it in gear
i had all four off the ground and put it in gear and had a friend push down on the clutch
wheel were still spinning until i put abit of force onto the fork to help push it and it stop spinning
slave had to b modifyed but there is no leaks
master cyclinder has no leaks too
pedal has been adjusted to the max so it has a longer stoke
been bleeded heaps of times
could the slave cyclinder be stuffed??
i will get measurement and pics later on today and see how much should the slave cylinder should b pushing
thanks
Old Feb 3, 2012 | 06:53 PM
06RedRalli's Avatar
http://www.evomoto.com/tech_articles..._article_id=28
Have you tried clutch pedal adjustment?
Old Feb 4, 2012 | 02:45 AM
jacksons's Avatar
gooov
13
Mar 19, 2015 04:41 PM
iidrakeii
Nov 12, 2011 06:24 PM
EXTRMPSI
Jun 9, 2011 09:04 PM
joosdawg
Dec 18, 2007 07:58 PM
Biggwill91183
Lancer Troubleshooting
Nov 21, 2006 09:22 AM
