Works Vs Jun Vs Hks
Old Jan 19, 2004 | 08:16 AM
  #31
QuantumEVO's Avatar
Originally posted by MrBonus
Who sells the Tomei cams here?
www.boost-solutions.com
Old Jan 19, 2004 | 08:18 AM
  #32
Erik@MIL.SPEC's Avatar
On lancerregister.com , all the British and Euro guys swear by the Piper cams. People should check those out to like QuantumRacing said.
Old Jan 19, 2004 | 10:14 AM
  #33
QuantumEVO's Avatar
I carry Piper. Some sets in stock.
Mark
www.Quantum-Racing.com
Old Jan 19, 2004 | 10:37 AM
  #34
When is your website going to be up? Mmmm, I LOVE pictures.
P.S. Sorry for the short hijack...
Old Jan 19, 2004 | 10:43 AM
  #35
QuantumEVO's Avatar
Should be soon.
Mark
Old Jan 19, 2004 | 11:32 AM
  #36
BPAuto's Avatar
Silver Sponsor
We carry Marisa Tomei cams.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Jan 20, 2004 | 07:09 AM
  #37
silverEVO8's Avatar
PM'd you
Old Jan 20, 2004 | 08:09 AM
  #38
maki's Avatar
Hi
I believe Al did some testing and JUN came out on top
he bought both 264's and 272's and both made more power then HKS
Old Jan 20, 2004 | 08:12 AM
  #39
maki's Avatar
Originally posted by jbrennen
Just repeating something I read on here, but I was under the impression that the JUN cams weren't designed to work with the stock valvetrain. The HKS and Works cams are designed to work with the stock valvetrain.
If that's true, the extra cost of replacing the valve springs (and retainers?) should be considered along with the JUN cams.
I am running the HKS 264i/272e combination. No numbers or dyno sheets (yet), but the car pulls like a champ all the way to the 7600RPM fuel cutoff.
actually you are wrong, JUN cams are no different from HKS
lift is higher but only slightly, so there is no need to upgrade retainers and springs. JUN recommends using racing springs and so does HKS, but most vendors ingnore it because those are expensive. Many people on this forum have JUN, some bought stage 2, but most just got cams alone.
Old Jan 20, 2004 | 08:45 AM
  #40
en1gma19's Avatar
It all depends on what you want out of your car. You can't really go wrong with any of them. As for idle, I hvae read many posts from guys with 272's that have no problems with idle. That mostly depends on the tuning. The bigger turbo you have, the more lift you want to help spool it faster. More duration helps too. I've read that cam gears are not needed with HKS 264's. Not sure about others. If you go with Jun or Tomei I would suggest getting retainers and springs too. Better safe than sorry.
Old Jan 20, 2004 | 01:02 PM
  #41
jin88's Avatar
For those who are worry about idle, remember with a motec or autronic or any stand alone unit that has that option, you can always adjust the idle.
Old Jan 28, 2004 | 08:54 PM
  #42
jstockdale's Avatar
Works 269 Cams, P2, Aperature, and Exhaust on the dyno:
https://www.evolutionm.net/forums/sh...663#post710663
-S ...
Old Jan 30, 2004 | 10:31 AM
  #43
evo542's Avatar
what's the difference between those and regular tomei cams?
Old Jan 30, 2004 | 10:50 AM
  #44
MrGozo's Avatar
Re: Works Vs Jun Vs Hks
Originally posted by Yaroslav
I`m deciding which to buy ?
WORKS CAMSHAFTS?
JUN?
HKS?
What do you think?
Or if you have it on your car, share.
For every day car.
Thanks a lot
dude go with hks or jun, forget about tomei or works
both jun and hks are pruven to make crazy hp
Old Jan 30, 2004 | 11:04 AM
  #45
mayhem's Avatar
Re: Re: Works Vs Jun Vs Hks
And works is proven to. these posts stating stuff without anything to back it up are getting old.
