Location of Final Drive Gears
Old Feb 9, 2012 | 04:12 AM
sparky's Avatar
I need a class in Evo Drivetrain Design 101. Maybe someone can help.
I am thinking of doing a trade plus cash of my 2004 Evo VIII RS for a low mileage 2006 MR. However, I would like to swap the trannys on the two cars. That is put my RS 5-spd. into the MR and vice versa.
I want to of course keep the same final drive ratio. So, I understand how on a rear wheel drive car the ring and pinion gears are in the rear differential. But, where are the final drive gears located in the Evo? They can't be in the rear diff can they? Are they located in the trannie itself? Help!
If I just swap the two trannies will I still end up with the same final drive ratio? Or is there something else aside from the trannie that I'll need to swap out?
Old Feb 9, 2012 | 04:28 AM
binky's Avatar
The final drive gears are located inside the transmission.
-Bink
Old Feb 9, 2012 | 11:30 AM
RSMike's Avatar
Originally Posted by binky
the final drive gears are located inside the transmission.
-bink
+1
Old Feb 9, 2012 | 11:52 AM
SDevo13's Avatar
You are going to need to buy or make a conversion kit for both cars, as well as changing out the shift linkage on the cars. Best of luck, that sounds like quite a little project project.
Llew
21
Nov 19, 2025 06:38 PM
e_kobz
Oct 21, 2013 09:40 AM
vietdragontekx
10
Oct 7, 2010 03:10 PM
Turbo-Ron
Future Lancer / Evo Models
16
Jan 1, 2006 06:59 PM
rhyzin
Feb 27, 2004 08:51 PM
