Running HKS DLI II with Okata direct replacment coil packs
Old Feb 10, 2012 | 06:53 PM
Raceghost's Avatar
Hello all. Purchased the Okata Plasma Direct coils 6 months ago, like them, still want more out of the ignition... Purchased the HKS DLI II from AWD with out even thinking of the two working together. Anyone have any suggestions or hesitations? Please let me know, thanks in advance. Also, spark plug question, if they will work together, do I want to run a colder plug than normal, or one step warmer. Someone on here said if you upgrade your ignition you should run a hotter plug? Thanks again for getting me straightened around in advance.
Old Feb 10, 2012 | 06:58 PM
n2oiroc's Avatar
At your power level, stock plugs are best. As far as the coils, the dli increases primary voltage. It shouldnt hurt the coils, but it may shorten the life of them. That goes with any coil.
Old Feb 10, 2012 | 07:24 PM
Raceghost's Avatar
Is that at current power, or at 400? Also running, BPR8EIX NGK's.if I remember right, these are one step colder than stock?
Thank you in advance.
Old Feb 10, 2012 | 07:33 PM
n2oiroc's Avatar
I was going by your sig 400/400. 1 step colder is fine, but more likely to foul. Stock is preferred in cold weather though.
Old Feb 14, 2012 | 11:34 PM
Raceghost's Avatar
Bump. Anyone else, on running HKS DLI II with Okada Projects replacement coils?
Suggested from OkadaProjects.
・100% secondary current (Spark Amperage) increase
・4 Times Spark Energy Increase for the initial spark discharge
・Easy installation. Only replace stock coils to Plasma Direct.
・Compatible with all OEM components
・Compatible with OBD-II (On-Board-Diagnostics)
The HKS DLI II is an intial spark amplifier as well.
Any guru's?
Thanks again in advance. Nothing against n2oiroc, just want a second opinion if I could.
Anyone, Bueler... Bueler....
Old Feb 15, 2012 | 02:31 PM
Raceghost's Avatar
Bump...
Old Feb 16, 2012 | 12:56 AM
Raceghost's Avatar
Thank you for purchasing our product.
Yes, it should have no problem using our Plasma Direct in conjunction with the HKS Twin Power.
Okada Projects USA
www.okadaprojects.com/usa/home.htm
Name can remain anonnymous, but this is the email I recieved from Okada Projects directly today concerning this subject. Awsome! Thanks again for the quick reply guy's.
Ran it tonight with gap set at .30 and she railed to about 6 and then had a flame out or blow out, so need to check grounds, and possibly regap to .28. But, the idle was so sexy.
Old Jun 20, 2012 | 09:46 AM
evolutong's Avatar
Subscribed
Old Jun 20, 2012 | 02:52 PM
okevolutionVIII's Avatar
Originally Posted by evolutong
Subscribed
This thread is over 4 months old.....
NJ_evoIXgsr
Mar 9, 2017 05:57 PM
Freddy302
Mar 7, 2016 08:45 AM
Pale Horse
Nov 14, 2013 10:29 PM
CNano8
Nov 28, 2008 04:01 PM
PVD04
Sep 12, 2005 10:34 AM
