Evo 8 idle problem Please help!!!
Old Oct 16, 2018 | 09:21 AM
kaj's Avatar
kaj
Start by making sure the BISS is adjusted correctly. If it's not, the IACV may have trouble keeping up.
Old Oct 16, 2018 | 09:31 AM
hesh7860's Avatar
how do i know if it's adjusted correctly or not
Old Oct 16, 2018 | 09:36 AM
kaj's Avatar
kaj
EvoScan will tell you what the IACV trims are. If you can't log data, I think there is a way to kinda do it by setting idle with the IACV unplugged.
Also, check for vacuum leaks.
Old Oct 16, 2018 | 09:45 AM
hesh7860's Avatar
Unfortunately i do not have EvoScan. Do you know another way to adjust it without it and i checked for leaks, nothing out of the ordinary im still holding proper vacuum at idle as well.
Old Oct 16, 2018 | 10:00 AM
kaj's Avatar
kaj
A search on this site should bring up a number of threads. I'm 99% sure I've seen a few on how to do it.
FoxFMX
Apr 21, 2024 03:42 PM
Omartrrs97GTS
Lancer Engine Management / Tuning Forums
Oct 20, 2018 01:37 PM
Omartrrs97GTS
Lancer Engine Tech
Nov 9, 2017 02:16 AM
TomasThijs
Apr 2, 2016 02:55 PM
