need help choosing a turbo D':
Old Feb 18, 2012 | 09:35 AM
TRACK FAMOUS's Avatar
I'm buying a Hellman MBC, from what I found there is a mustang dyno in the across town, only thing is that the tune is an e mail tune so it's gonna be road numbers, I'm leaning towards the map ef3 though
Old Feb 18, 2012 | 09:37 AM
Levar's Avatar
Veteran: Army
Originally Posted by ct9asilver
The Muse LICP, ETS LP2 or MAP LICP are all an improvement over the Injen LICP. Your Injen UICP is fine though, the couplers that are supplied with the kit are sometimes an issue, they blow off occasionally, mostly were the UICP meets the TB, The issue is that the supplied couplers are too short. I would get new couplers for the UICP and get one of the above mentioned LICP'S
For the price, you cannot go wrong with either of those LICPs. I had the Injen UICP and LICP on my last EVO and they always broke off from the throttle body and intercooler. I now have the BR UICP and MAP LICP.
Old Feb 18, 2012 | 09:41 AM
getsideways's Avatar
Hallman is exactly what i use on my EF3 it works very well. It will be a road tune then just like the graph i posted above.
Mellon really knows his stuff and will be able to maximize your setup! And theres nothing wrong with the road dyno when you use it properly, it gives real world numbers that your making at the time, Just make sure you weigh your car and find a nice smooth and SAFE road.
Ya, hopefully I can tickle that 400 with what I have now
And in the near future start to change out cams an pipes, anything else
I should know?? You all have been extremely helpful, thank you
Old Feb 18, 2012 | 09:43 AM
Levar's Avatar
Veteran: Army
Originally Posted by getsideways
The other big factor about the boost control is the Full and Green will almost surely require a 3 port to reach into the 400WHP range on the stock block on 91 octane. They spool great which means an awesome torque hit but it needs to be controlled if you want to keep everything safe, this is one of the major reasons i lean towards the next step up in turbos on the stock block is they are actually a little safer/ easier to modulate the torque hit.
I totally agree as we do not need a window in the block.
Pull the trigger.
Old Feb 18, 2012 | 09:54 AM
Keep an eye on your injectors, I know Mellon will be watching them and at 400 you should be fine with the 720s but if you start to push it you will certainly be pushing them to their max. I used an 850 FIC to make my number i posted and they were pretty much maxed out.
Keep us posted on what you end up with, and like i said be sure to call the guys at map Dan will probably be a little easier to get ahold of but if you can reach Chris hes king of the castle.
Old Feb 18, 2012 | 09:56 AM
Forgot to ask do you have a baseline dyno graph for what your car is currently making?
Old Feb 18, 2012 | 10:27 AM
Na I don't, had the paper but got lost when I moved, I was 316 whp
But the torque I can't remember
Old Feb 18, 2012 | 11:49 AM
Sounds about right for the mods you had listed GL on the purchase Keep us posted with what you end up with!
Old Feb 18, 2012 | 12:10 PM
Sidnakit's Avatar
I kinda liked the all caps.. Huh??
Psybin
Evo X How Tos / Installations
Aug 29, 2014 12:41 PM
JonGonzo
Jan 15, 2014 01:58 PM
JDavenport
15
Nov 25, 2013 07:03 PM
cncledout
Oct 30, 2012 11:51 AM
nollij
Member Unresolved Disputes
May 14, 2012 09:24 AM
