Pulled the Transmission!
Old Feb 26, 2012 | 05:23 PM
THUB's Avatar
ARP includes grease with their flywheel bolts, not loctite, specifically because they seize into the crank so often. Don't use loctite. Just make sure you torque to 98 Ft/Lbs.
Old Feb 26, 2012 | 08:12 PM
xXANCHORMONXx's Avatar
I dont know if it means anything buy friend built his own Subbie 2.5rs and he said he would never use loctite
Old Feb 26, 2012 | 08:28 PM
ElectricBlueIX's Avatar
I've paid for my clutch job the last three times and that's getting old! I'm mechanically inclined and have done plenty of clutch jobs...just not on an EVO. Next time I'm doing it.
Old Feb 26, 2012 | 08:46 PM
gpfury86's Avatar
I use loctite and know plenty of people that do, just heat them up a tad when u take them out. They were in there, but I didnt have any trouble. I used new oem bolts though. You can do it however u like, but those aren't something you ever want coming loose..... I used red loctite and torqued to 95 ft lbs
Old Feb 29, 2012 | 03:25 PM
Is loctite used from the factory?
Old Feb 29, 2012 | 04:17 PM
THUB's Avatar
No. From the factory the bolts are dry. Using loctite is an almost surefire way to give yourself problems next time you try to remove the bolts.
Old Feb 29, 2012 | 08:35 PM
friedchicken24's Avatar
hey man congrats like you im also 19 and going to do the clutch myself in a month or so im just getting everything i need and since im down there thinking of what i could change. im doin it just for the experience and to get closer to my evo.
Old Mar 1, 2012 | 12:30 AM
Congrats, I recently got the car, I'm from the VW world so it's alittle different.
A few things that helped is make sure you have a good jack and some jackstands that go pretty high.
I'm replacing everything.
The transmission is getting rebuilt.
Shifter bushings are going in.
There's a pia mount in the back of the tranny. I'm upgrading it.
I'm replacing the whole clutch fork assembly too.
Clutch fork
Clutch fork boot
Clutch fork sleeves
Felt washers
Clutch fork springs
Clutch fork pin
I'd say that's just about everything that is important to change.
Also I bought a mini pump for the tranny case fluid. Basically you fill from the drain hole as soon as it comes out of the fill hole you close it do two more pumps and quickly put the drain plug on.
That's the simplest method I've seen.
My transmission only grinded at wot but I figured I might as well get it rebuilt while it's out.
Old Mar 1, 2012 | 12:31 AM
That's what I'm thinking too
Old Mar 1, 2012 | 05:25 AM
yeah well me im thinkin about taking out the t case to go get it rebuild. i dont know how the last owner drove so it would be better to be safe then sorry.
Old Mar 1, 2012 | 09:26 AM
desiromeo812's Avatar
Bump for a Norcal local. Let me know if you need any Help with the car or ever have any questions. Always down to Help locals
Old Mar 1, 2012 | 04:44 PM
For sure thanks!
Old Mar 4, 2012 | 03:09 PM
Got the transmission in, hardest part hands down was getting the transmission lined up.
Every feels way better andddd no more rattling on decel!
Only issue I have is that if the car is not moving and I try to row through the gears it is tough to go into fourth. But if im driving and go from 3rd to 4th no problems..
jimbo74
Lancer Engine Tech
Jul 29, 2016 04:27 AM
InoNothingMR
For Sale - Wheels / Tires
16
Aug 26, 2015 01:39 PM
R3VOLUTION
Apr 29, 2015 12:12 PM
R3VOLUTION
For Sale - Cars For Sale
11
Jun 30, 2013 01:52 PM
EvoLeoIX
South Region
Jan 28, 2012 09:42 AM
