Pulled the Transmission!
Old Feb 23, 2012 | 10:57 PM
xXANCHORMONXx's Avatar
Hey so i bought an EVO8 about a month ago. Soon after the clutch was slipping and I had a 5th gear grind.
So I decided to bite the bullet and pull the transmission to get rebuilt and put in a better clutch.
So I bought a clutch masters fx300.
Then I also decided it would be fun to drop the transmission on my own with some help.
Glazed flywheel
Glazed pressure plate
The transmission was brought to FFTEC in Hayward they specialize in Evo 8,9,10 and all DSM 1g ,2g etc
It's having a complete rebuild with upgraded sychros as well as gears replaced if needed.
What's cool is that they use the same rebuild I'm getting on their 9 second beast.
Overall it's alot of money for being 19 but I rather have the power train be solid before I start swapping turbos.
After getting it out I'm really proud of myself, the most I've done is bolt ons. It took me and my friend about 5 hours to do the whole thing on jackstands and using regular tools..
ETA is two weeks on the rebuild mainly depending on the status of the gears.
I also bought a new Clutch fork, Clutch fork shaft, Springs and those little felt washers.
Seeming like a good time I bought a Powerflex Motor Mount insert for that PITA transfer Case mount ans Agency Power Shifter bushings.
ALSO:
I was very worried about this becuase of the struggles some people have dealt with to remove the output shaft from the transfer case.
The bolts from the oem downpipe hangars fit perfectly into the out put shaft. We threaded that bolt and twister a metal coat hangar around the bolt and tied the other end to a 3 pound sledge hammer. About 5 pulls and it was out.
Old Feb 23, 2012 | 11:01 PM
bphx123's Avatar
if i need my tranny replaced, ill make sure i hit you up. haha
Old Feb 23, 2012 | 11:16 PM
THUB's Avatar
This brings back memories. I was 19 the first time I pulled an evo trans out. It was an experience that ended up giving me the confidence to do all kinds of cool stuff since then. Good for you.
Old Feb 23, 2012 | 11:36 PM
Haha I think I would be up for it, as long as you have a second hand it can be done.
I met Sean today at fftec, I cant wait till I start putting some parts on this thing and to finally get it tuned over there.
Thanks, I feel that after this everything will be a bit easier
Old Feb 24, 2012 | 12:53 AM
Throttle's Avatar
good to hear your success. i'll be doing my first timing belt change in the summer. it will be my first major job on a car. wish me luck.
Old Feb 24, 2012 | 01:58 AM
SDevo13's Avatar
buy the $30 tool from AMS. it will make your life a lot easier. Holds cams in place while belt is off.
Old Feb 24, 2012 | 05:00 AM
boostaddikt's Avatar
Nice!! I just did my clutch a month ago.., I was very nervous when I started to do it but now feel like I can do almost anything lmao... Doing it on jackstands sux though... Nxt time I'm using a lift
Old Feb 24, 2012 | 05:31 AM
ihockey1's Avatar
+1 or the timing tools kit from jays racing
Old Feb 24, 2012 | 05:37 AM
gpfury86's Avatar
I had the same exact story bought an '05 evo viii and the clutch was slipping with a 5th gear grind. Wasn't my first evo clutch job though. Pulled my first motor/tranny out of my 1st gen awd dsm at 17 been addicted to the 4g63 platform ever since lol. Btw make sure u red locktite all the flywheel/ pressure plate bolts and torque them down to specs.
Old Feb 24, 2012 | 09:29 AM
delongedoug's Avatar
My clutch blew so I didn't have a choice but since I already had the 5th gear synchro grinds I decided to have it rebuilt while it was out. Not something you want to do any more than you have to. It's expensive but best to do it all at once.
Old Feb 26, 2012 | 10:46 AM
Thanks for the loctite info I heard it was red loctite on the flywheel and blue on the pressure plate?
Who rebuilt it for you?
Old Feb 26, 2012 | 11:02 AM
See signature. Shep
Old Feb 26, 2012 | 11:56 AM
THUB's Avatar
Do not use loctite on the flywheel bolts.. they are to be installed dry. Loctite will seize the threads in a more permanent way than you want.
Old Feb 26, 2012 | 05:03 PM
See signature. Shep
Completely missed that lol my fault
Oh man Im getting 20 different recommendations lol
Old Feb 26, 2012 | 05:15 PM
hiboost2.0's Avatar
In my personal opinion I wouldn't use loctite. If the bolts are torqued correctly they will be fine. Also the lubrication could give you inaccurate torque readings? Just a thought.
