older GSC springs & Chromoly rets
Subscribe
Feb 26, 2012 | 10:54 PM
couldn't find any info about this old setup, searched on GSC website but no luck. only know that they were quoted for $229 in 2008 if anybody knows what are the spring rate of these, are they direct swap for oem springs and will this setup work well with newer S2 cams ?
any input is greatly appritiated. thanks in advance
Reply 0
Feb 27, 2012 | 12:29 AM
call Greg @ GSC on 1-866-548-4GSC
Reply 0
Feb 27, 2012 | 07:52 AM
You must be referring to the non-bee hive singles. I ran those springs for almost 3yrs with
S2s. They are a direct swap but you will need those retainers as the stock will not fit. I don't know the spring rate but do know the lift limit @ 11.5mm
Laramie
Reply 0
Feb 27, 2012 | 10:46 AM
thanks for input guys, very good info
laramie_05MR
what was your rev limit ? so guessing they would be ok with newer S2-s 11.2 peak lift ?
will double check with Greg as well
Reply 0
Feb 27, 2012 | 10:51 AM
Rev limit was 8k.
Reply 0
Mar 6, 2012 | 12:31 PM
called Greg but no response so far..
if anybody else can give any feedback about these, post up, any info is appritiated
Reply 0
Mar 7, 2012 | 03:44 AM
bump for more info
will they work well with S2's
Reply 0
Mar 8, 2012 | 07:23 AM
bump for help
Reply 0
Mar 10, 2012 | 07:43 AM
bump
Reply 0
Mar 15, 2012 | 02:03 PM
PM sent
Reply 0
Subscribe
