Ams 2.3rr reliability and questions :)
Old Mar 16, 2013 | 05:44 AM
  #31
evl08's Avatar
Originally Posted by Aussie IX
My HKS 2.3R kit recommened a 1.2mm gasket for a 9.1 compression.
My mechanic recommended I use a Tomei 1.5mm gasket, so I did.
So that would lower my compression. Now I have a larger turbo, I have a lot of lag, should I go to a thinner gasket to get a higher compression to reduce my lag?
If so, what size should I go to, as I mainly want to reduce lag, and get a better daily drive on E85, rarely using pump fuel.
Changing the gasket won't help to improve spool. Increasing compression just squishes the same amount of air more. It might help a little to improve out of boost drive ability, but not that noticeably moving from somewhere around 8.8:1 with the 1.5mm to 9:1 with the 1.2
Old Mar 16, 2013 | 02:38 PM
  #32
Aussie IX's Avatar
Yeah, I was hoping it would shift my power left. But I might just leave it a put on a supercharge to help spool LOL
Here's a graph of my power, heaps of lag.
Old Mar 16, 2013 | 03:18 PM
  #33
PatricksEvilEvo's Avatar
^Ouch. That's what an HKS 2.3L and Blouch bb 80R produces? I see people on here having far better luck with stock block fp black setups.
Old Dec 7, 2014 | 03:40 AM
  #34
Aussie IX's Avatar
Yeah, finally gave up on the Blouch and went with a locally made turbo GTP762. This is my track tune, getting full boost and stock power around 3750rpm. Street tune is at 32psi making about 370kw's
Fireescape
18
Feb 2, 2016 07:46 AM
OneCrzyEvo21
60
Apr 9, 2015 07:53 PM
spadednick88
For Sale - Cars For Sale
29
May 15, 2013 08:56 AM
Blitz
12
Oct 30, 2007 08:44 PM
EVOclub4
234
Aug 28, 2007 04:33 PM
