coolant pushing to overflow
Old Sep 11, 2012 | 01:17 PM
  #76
lude2evo's Avatar
there is a tsb on the radiator cap, but its usually caused by a lifted head(which warps the gasket) or a warped/bad headgasket. what happens is combustion pushes past the thermostat into the radiator and once its full the overflow tube does its job. the issue is it constantly pushes combustion and the overflow tube can not draw the coolant back in. i actually just changed my gf's head for this very reason not too long ago
Old Sep 29, 2012 | 12:58 PM
  #77
pistonless's Avatar
I am also having the same problem. I am running the headstuds below with an HKS headgasket. I have changed turbo setup and remapped the car on a 2.0LR 6262 setup using 33psi boost.
Are these headstuds strong enough?
http://www.maperformance.com/map-hig...11mmalloy.html
Old Oct 4, 2012 | 06:18 PM
  #78
The-Evo's Avatar
Iam using the exact same setup as you with the exception of the head gasket. I am using oem head gasket. I originally had a head gasket issue due to improper torquing. I replaced head gasket and had the head milled and then I started having overflow problems. I believe the radiator cap may have become damaged when the head gasket was bad. I replaced the cap and it seems to be okay now. Hope what I told you helps?
Old Oct 4, 2012 | 06:52 PM
  #79
nytalonTSi's Avatar
My overflow when cold is at the full mark. When at full temp it rises to just under where those small numbers are. Even when I stay out of boost.
I'm no expert but from my experience, the overflow always rises a noticeable amount when the coolant heats up.
The-Evo, did you go with another OEM rad cap? Those 1.3's put extra stress on the cooling system.
Old Oct 6, 2012 | 08:10 PM
  #80
Randal's Avatar
Guest
Originally Posted by ta ace
coolant pushes to my overflow bottle ONLY after a WOT pull ..
doesnt smoke or
run bad or
have bubbles in coolant or
milky coolant or
milky oil
maybe the head lifting??
L19 studs cometic HG torqued to 100 lbs
coolant pressure test it holds pressure no leaks.. aany ideas?
just went to FF 6262 setup only at 33 psi now was at 40 on old setup w/o issues but w/ full size radiator.
any ideas? think the HG is just blown?
Yes HG is blown, you are building excess pressure in the coolant system and it needs to go somewhere.
Old Oct 7, 2012 | 05:25 PM
  #81
The-Evo's Avatar
Yes I did. I bought a mishimoto radiator and it came with a new 1.3bar radiator cap with it.
Old Oct 22, 2012 | 09:20 PM
  #82
TeachersEvo's Avatar
An update on mine: still pushing after new cap and t stat. Gonna do the head gasket next month. F frustrating issue as i have great compression and no fluid mixing but i don't see what else it could be at this point. Any other thoughts before i take the big plunge?
Posted from Evolutionm.net App for Android
Old Oct 22, 2012 | 09:29 PM
  #83
The-Evo's Avatar
Sorry to say, but at this point, it's definitely a head gasket issue. What head studs are you using. Is it a built motor/head? What psi are you pushing?
Old Oct 23, 2012 | 07:46 AM
  #84
Factory 9 everything, except for a TBE and a tune. It's at about 18psi-ish I believe and it is still on the factory head bolts. I bought head studs and a head gasket. Weird since it never pushes coolant when boosting, only when it's up to full operating temp and I drive it long distances.
I have a sneaking suspicion the PO used stop leak on it to get it by until he could sell it (to me) but there isn't quite enough residue in the overflow tank to know for sure. Oh well, it needs head studs anyways.
Old Oct 23, 2012 | 09:26 AM
  #85
10isace's Avatar
Do you have any oil residue in your coolant? It should collect at the top of the radiator neck or in the overflow bottle. Mine looked like small specks of dirt at first.
I made this thread so you can see what it looks like. https://www.evolutionm.net/forums/ev...ption-3-a.html
Old Oct 23, 2012 | 09:29 PM
  #86
Nope no oil in there. Wish it was that simple. One of the first things i checked for.
Old Oct 29, 2012 | 07:50 AM
  #87
pistonless's Avatar
Update for you guys.........mine was the Rad cap.....Greddy 1.3bar Rad cap has done it for me
Old Nov 5, 2012 | 04:44 AM
  #88
dsm6382's Avatar
cometic HG not good
my experience is Cometic HG are not very good at least on the Evo platform. get somthing with a stopper layer or integrated fire ring . somthing like the Power enterprise HG or Cosworth HG . i have had the best luck with those two HG on 30psi 582WHP VD . running 10.92@130.9mph. on street tires 1.8 60 foot. the Power enterprise HG has lasted over a year of racing now . never push any coolant at all ...knock on wood. A huge factor too is spool up and max tq/boost timing tuning.. i am currently on 3 deg at 5k rpm @320 load.and 6 deg at 5500rpm 320 load steady going up to 19deg @7500. .. you want to have low timing at peak tq /boost in the high load cells..timing should be set at between 2-6 deg in the max boost/peak tq range at high load cells is ideal. too much timing at peak boost/tq and you will go thru many a HG .
Old Nov 6, 2012 | 01:20 PM
  #89
sil80evo's Avatar
I would check that radiator again.
Old Nov 7, 2012 | 06:43 AM
  #90
quick update: mine was absolutely a blown head gasket. both head and block warped (from the P.O. I assume, it's never overheated when I had it) out about .015" which is quite significant. They warped the same direction, however, instead of away from each other masking my symptoms pretty severely.
Just a run down of symptoms:
Pushing coolant, but only on long drives
Perfect compression 155-155-155-155 (Mitsu FSM for the car states 145 as normal for a IX)
No mixing of coolant/oil or vice versa
No significant loss of power that I could notice.
Never overheated, under boost or otherwise (as long as coolant kept up to proper level)
Minor coolant consumption, but mostly just pushing it out of the res.
Basically, the symptoms you might expect from a bad rad cap, except mine was a blown head gasket (that was actually quite severely warped.
Food for thought--- thanks to English Racing for taking on the work of doing the job.
