Not getting a Spark on 05 Evo 8.
Old Mar 4, 2012 | 07:56 AM
derangedazn's Avatar
Trying to diagnose why the evo isn't getting any spark. Trying to rule out all other possibilites before replacing Crank Position Sensor.
Pertinent Modification:
Drop in Filter
Spoolinup COP
Evo IX DV
What I have checked:
Fuel Pump works (I can hear the walbro come on)
All fuses checked under the hood
Changed all spark plug (previous smells of fuel but tips are fine, no indication of lean)
Cam Angle Sensor replaced (thought it was the problem so bought a new one)
Put stock ignition plugs back on to rule out
Battery charged
Pulled Plug 4 and not getting a spark.
Back Story:
One week ago, went to take the car for a drive. Car started normally. No abnormal delays. Warmed the car for approximately 10 minutes. Drove 1.5 miles to a stop sign. Went to go, and thought I stalled the car out. Car would not start up again. Some friends and I pushed the car back and now it sits in the drive way.
Please help.
Old Mar 4, 2012 | 08:06 AM
AJCaron12's Avatar
These threads with coil on plug kits doesn't really make me wanna get one.
https://www.evolutionm.net/forums/ev...need-help.html
Old Mar 4, 2012 | 08:08 AM
I put the factory ones back on and still not getting a spark. I do not think it is coming from the COP.
Old Mar 4, 2012 | 08:10 AM
SDevo13's Avatar
Sounds like a cam angle/crank angle sensor problem. That is exactly what happens when they don't sync
Old Mar 4, 2012 | 08:13 AM
AJCaron12's Avatar
I assume you don't have any codes?
Old Mar 4, 2012 | 08:15 AM
No codes.
Old Mar 4, 2012 | 08:21 AM
That is what I leaning towards. Just trying to rule out other possibilities before replacing that sensor.
Old Mar 4, 2012 | 09:32 AM
AJCaron12's Avatar
Do you know anyone with a decent scan tool? If you watch RPM's on the scan tool while cranking and it stays at zero, that usually indicated a bad crank sensor.
Old Mar 4, 2012 | 10:04 AM
I forgot to mention. My buddy hooked up evoscan and it read 0.
Old Mar 4, 2012 | 10:10 AM
nytalonTSi's Avatar
Did you check the ignition fuse inside the car? Under the dash? It's behind the change tray you have to pull.
Cause I read you only say you checked fuses under hood.
Old Mar 4, 2012 | 11:25 AM
AJCaron12's Avatar
Put a crank sensor in it. OEM too.
Old Mar 4, 2012 | 02:11 PM
Thanks. Will definitely give that a look.
Old Apr 29, 2012 | 10:39 AM
update...
Replaced Cam Angle sensor and crank position sensor. No crank play noted. Car still does not start.
Any suggestion would greatly be appreciated.
Old Apr 29, 2012 | 01:12 PM
studioface's Avatar
I would still think its a electrical issue seeing you are not getting any spark on #4 maybe some fuse,ecu or bad wires?
Old Apr 29, 2012 | 02:08 PM
selecta's Avatar
You're supposed to upgrade your ignition fuse when you install the spoolin up kit i believe its a 25amp from a 20 amp have you checked the ignition fuse?
