Clutch/gear shifting issues
Old Mar 18, 2012 | 05:15 PM
Rmatthew987's Avatar
Originally Posted by Team Foren
If you can't shift it with the car off, it's not the clutch. You either have a linkage problem or an internal problem in the trans.
When the car is running and you try to shift it into gear with the clutch depressed it starts to roll after it gets rolling a little it will pop into gear an somewhat shift normally. I was told it could be a broken pressure plate or spring from the hub or possibly a bent fork? I'm going to try to bleed the new slave tomorrow and see if that makes a difference and I'll check the linkage. The thing that stares me away from it being the linkage is that once I get it going it shifts with no problems it's just engaging it the first time from a dead stop
Old Mar 18, 2012 | 05:27 PM
sna08's Avatar
Originally Posted by Rmatthew987
Hey not trying to thread jack but I'm having similar issues maybe we cna kill two birds with one stone.
Situation-cruising in 5th coming up on a light went to downshift into 4th and grinded so slowed some more in neutral and tried third same bs again slowed more.....
Grinding has more to do with your syncros than anything else I believe. My issues is at a stand. If its rolling it'll go into gear fine.
Old Mar 18, 2012 | 05:32 PM
sna08's Avatar
The mechanics may have forgotten to lubricate your input shaft so the throwout bearing slides easier. If it were me I would carefully try to spray some wd40 through the access hole. Be careful not to get any on the clutch. If it shifts better with the engine running, then you know you need to drop the trans and lube it properly. Good luck
I will bring this up with him... Sounds like it might just be this...
Any other suggestions?
Old Mar 18, 2012 | 05:39 PM
Team Foren's Avatar
If lube is the problem. Make sure your mechanic doesn't overlube the input because that can destroy your clutch.
Old Mar 18, 2012 | 05:52 PM
Well the grinding issue I just figured was because the clutch wasn't being fully disengaged when I was trying to shift causing it to grind as if I wasn't using the clutch at all.
Old Mar 18, 2012 | 06:10 PM
sna08's Avatar
I try to engage first and it won't go in but the car starts to roll forward as if it's semi in gear with the clutch fully depressed. It won't shift into gear with car off with or without pushing the clutch in. I was told it could be the pressure plate or spring came loose or something similar. Any ideas? I don't want to order a new clutch kit just to find out it wasnt the issue.
Have you adjusted your pedal? Bleed clutch?
I did both and adjusting pedal higher seemed to helped. Bleed clutch and air came out a bit but still a bit hard to go into gear...
Do my clutch in pic look like it's releasing all the way?
I think we both are having disengagement issues.
Old Mar 18, 2012 | 06:22 PM
I'm going to bleed the clutch again tomorrow and hope that solves the problem if not I'll probably try to adjust it higher but again I doubt that will help as the pedal shouldn't have moved from the previously workin position.
Old Mar 18, 2012 | 06:53 PM
sna08's Avatar
As your clutch wears, it gets thinner and modern slave cylinders adjust for this... hence the need to adjust the clutch from time to time especially if you've never adjusted before.
Old Mar 18, 2012 | 06:55 PM
sna08's Avatar
Here's a how to in case anyone needs it.
https://www.evolutionm.net/forums/sh...d.php?t=260040
Old Mar 18, 2012 | 07:21 PM
sna08's Avatar
Will do. Thanks. The input shaft is always spinning with the flywheel correct?
Old Mar 18, 2012 | 09:12 PM
xXANCHORMONXx's Avatar
sounds like clutch drag
Old Mar 18, 2012 | 10:41 PM
sna08's Avatar
I thought it was to until I rev'd it to 5k clutch in on 1st gear... Car didn't move.
Old Mar 19, 2012 | 06:28 AM
Team Foren's Avatar
No. Your input shaft is splined to the clutch, it only should spin when your foot is off the clutch. The flywheel and pressure plate spin at all times with the engine. Your TOB also slides back and forth on the input shaft. If it isn't greased properly it can bind and your clutch won't fully release making it hard to shift when the engine is running.
Old Mar 19, 2012 | 12:29 PM
sna08's Avatar
Man that make so much more sense now...
Old Mar 19, 2012 | 04:24 PM
sna08's Avatar
Unfortunately the mechanic said he already greased it up...
If my "pill" is clogged would it have this symptom? Hard to shift issue
