Clutch restrictor pill removal long term update anyone?
Old Mar 6, 2012 | 10:05 PM
sna08's Avatar
Originally Posted by cfdfireman1
yourself?
A shop my buddy recommend. They used extra s which is 75/90 and most popularly used by subies I believe ours is 75/85 (diaqueen anyways).
can this be the cause?
Old Mar 6, 2012 | 10:10 PM
sna08's Avatar
Originally Posted by Vivid Racing
Removing the pill won't fix a broken clutch. It'll just make clutch engagement/modulation feel a lot better.
I'm not sure its broken. Nothing is grinding and it shifts perfect when car is off. It is a new clutch installed by a reputable shop
It has to do something with it being on... Maybe clutch isnt fully released when on? I'm not sure how it all works.
Old Mar 7, 2012 | 04:52 PM
cfdfireman1's Avatar
sna did you have this problem with the old clutch?
Old Mar 7, 2012 | 05:16 PM
boostedwrx's Avatar
My opinion is that the restrictor is there for a reason from the factory, to limit how fast the clutch reacts in an attempt to limit shock or stress on the drivetrain. Tards that can't shift or like to side step the clutch should not attempt this mod
Old Mar 7, 2012 | 09:28 PM
sna08's Avatar
I do know for a fact that it's there to save the drivetrain from damage.
What I want to know is if it'll cause me to be locked out of first gear...
Yes the problem was there with the old clutch as well.
Old Mar 8, 2012 | 07:58 AM
That pill is a spring loaded one way check valve that limits "engagement" speed of the clutch not the "disengagement", taking it out won't help the problem you describe. You could try a different fluid in the trans like "LubroMoly" or Amsoil night and day difference in the feel of the shift.
Old Mar 8, 2012 | 08:24 AM
sna08's Avatar
I will try it... Amsoil mtg I believe?
Old Mar 8, 2012 | 09:49 AM
griceiv's Avatar
the restrictor pill will not lock you out of first gear. Your clutch is not releasing, causing the lockout. lots of reasons that can cause your clutch to not release completely, most of them involve pulling the trans back out.
Old Mar 8, 2012 | 10:39 PM
sna08's Avatar
Can transmission fluid cause lock out on first?
I ask because they used 75-90 extra s fluid... For subies
Another thing I notice from day one is when I let go of the clutch in neutral, I can hear and see the rpm drop slightly... Is that the dragging issue people refer to?
Old Mar 9, 2012 | 07:40 AM
griceiv's Avatar
I don't see a problem with that fluid locking out first when stopped.
that's normal.
Old Mar 9, 2012 | 04:17 PM
will it go into reverse and the other gears?
Old Mar 15, 2012 | 12:49 AM
sna08's Avatar
They offered to replace fluids so I asked for oem. It felt slightly better till I played with adjusting the pedal. Now it's all the way up and really as high as it can be with a little play. It also seems to be a cold issue as well which is why I thought it was the fluids.
Im hoping it's not a tob issue.
The mechanic said because of my remote start and starting the car without clutching it, it messed up something that continues to spin when in neutral?tob? I'm not sure what he meant but I always start the car without the clutch and I'm wondering if this indeed messed up the tob?
sna08's Avatar
All the gears would be locked out as well at a stop light. If its rolling it'll go in no force/some notchyness...
Old Mar 15, 2012 | 08:29 AM
griceiv's Avatar
He's pulling your leg. Nothing wrong with starting the car in neutral without pushing the clutch.
Old Mar 15, 2012 | 07:36 PM
Did you bleed the clutch yet? And no you don't have to remove the air box to do it, you can get at it from below and take out the pill at the same time. If this doesn't take care of the issue the installer may have F'd something up on the install.
Starting the car with the clutch engaged will have no affect on what you describe.
