Clutch restrictor pill removal long term update anyone?
Old Oct 18, 2012 | 04:23 PM
  #46
Kreeker's Avatar
Originally Posted by sr20det91
Use OEM fluid in the tranny (diaqueen). Certain fluids make the syncros act funny effecting engagement. Everyone has their opinion on this, but in my case in it cured all my issue as far as gear lockout. It could also be your clutch pedal needing adjustment. How much play is at the top of the travel? If its more than factory spec you could possibly not be fully disengaging the clutch even when the pedal is on the floor. As far as the pill removal there are no cons unless your a careless driver. Pros are well documented; modulation etc..If your going to the trouble of bleeding your clutch its a no brainer to remove it. Should be the 1st mod all evo owners do.
My clutch engagement is high, but I don't have an exact distance right now.
Regarding the clutch not fully disengaging, is there anyway to test other than rev it 7k in first with clutch full depressed? I don't have evoscan yet so I can't disable 2-step.
Old Oct 21, 2012 | 05:10 PM
  #47
acidtonic's Avatar
I just removed my pill today. I've only driven about 2 hours on the new setup, but first impressions were that it grabs incredibly low.
It's literally *right* off the floor, but since the car only has ~600 miles on it I think it's just the brand new clutch. Before it would still grab low, but about 1.5 inches higher with a mushy feeling.
Now it's very direct and solid. Like others have said shifting 2-3 and 3-4 is much easier now without the notchy feeling.
I'm impressed at how easy it was on the X. It's right below the airbox and simple to get at. We had it off in 10 minutes tops. We noticed the metal rail connecting the assembly to the slave cylinder wants to bend as you're tightening the banjo bolt. We stuffed small pipe between the trans and the assembly while torqing the banjo bolt to keep it from turning with the bolt which prevented any issues.
Then we bled the clutch 3-4 times and topped it off. Drives great. What an awesome mod.
Old Oct 21, 2012 | 06:29 PM
  #48
Jturbo86's Avatar
removed it on my last evo, have not gotten around to doing it on this one. It's made the car much more enjoyable to drive and makes it seems as if our tranny's arent complete junk.
Old Oct 21, 2012 | 06:43 PM
  #49
masonh's Avatar
The mechanic said because of my remote start and starting the car without clutching it, it messed up something that continues to spin when in neutral?tob? I'm not sure what he meant but I always start the car without the clutch and I'm wondering if this indeed messed up the tob?
he's crazy or he's trying to steer you away from the fact that his install job isn't up to par
Old Mar 28, 2013 | 05:40 PM
  #50
MISHI's Avatar
Reviving for some info:
Reading around there are some that state the removal of the clutch restrictor can cause the TOB clip to dislodge from the pressure plate; is there any merit to this statement?
Also has anyone who wanted to keep the restrictor in ever tried modifying the plastic such as possibly drilling a slightly larger hole in the restrictor itself?
Thinking to do this in the E7 but not sure I want to risk having that TOB problem.
Old Mar 30, 2013 | 06:59 PM
  #51
MISHI's Avatar
Bump for info
Old Mar 31, 2013 | 11:01 AM
  #52
dastallion951's Avatar
My 0.02 its worth it. When my clutch was installed they put in the ss upper and lower lines, and adjusted my clutch pedal higher, works great. Im on act hdss with pro flywheel. Now at 50 k..... Just make sure to change your brakefluid and clutch fluid every 30 k or so.....good luck.
Old Mar 31, 2013 | 12:39 PM
  #53
zenoise's Avatar
Removing the pill was the best free mod I've done besides not letting my GF ride with me. Now I hear less *****ing when I drive.
Old May 6, 2013 | 09:07 AM
  #54
silverevo05's Avatar
On my list of things to do
Old May 6, 2013 | 10:13 AM
  #55
Erik@MIL.SPEC's Avatar
I have 166,000 miles on my Evo. Clutch restrictor pill has been out since at least 50,000 miles, if not sooner. Zero problems. And there is a cool new ACT solution for the clip on Evo pull cutches...
http://www.maperformance.com/blog/20...-rx7-and-more/
Old May 6, 2013 | 01:04 PM
  #56
wang4u's Avatar
Its been said many times, and even companies out there specifically tell you if its "lockout" or in other words, cannot go into gear, at any rpm, is called Clutch Drag. This means the clutch does not disengage all the way, thereby forcing the synchros to work much harder at matching the engines' speed. If forced into gear with this problem, instantly fries the syncro and output shaft.
See here: http://www.jackstransmissions.com/pa...kills-synchros
Best way to test your problem. Put into gear, rev engine to highest you can get (ideal to remove rev limiter or launch control), and see if the car creeps forward. Dont release clutch anytime during this test. This test proves if the clutch is dragging. If it does move, you have a list of issues it will be. Firstmost, starting with the installation, then the bleeding of the master cylinder. If it doesnt, then it might be installation error, bad transmission or bad trans output shaft.
CaptainCrunch
Jan 8, 2016 03:04 PM
Optiblue
26
Feb 20, 2014 01:05 AM
OC
Apr 15, 2013 08:33 AM
racer135
Mar 20, 2012 07:45 PM
LVSBB6
Evo X How Tos / Installations
13
Dec 16, 2011 07:04 PM
