quick head gasket question
Old Mar 21, 2012 | 01:00 PM
stunt2's Avatar
is 1005A700 (IX) head gasket direct swap for MN155760 (VIII) gasket. can it be installed on 4-8 engines without problems ?
Old Mar 21, 2012 | 09:50 PM
stunt2's Avatar
anybody ?
Old Mar 21, 2012 | 10:41 PM
LCS's Avatar
LCS
Nop. IX got mivec.
Old Mar 21, 2012 | 11:38 PM
stunt2's Avatar
anyone will confirm ? searched couple of threads, that say they are interchangeable for VIII, and wanted to double check
Old Mar 21, 2012 | 11:43 PM
EvoDom's Avatar
An ix head gasket will not work on an evo VIII.
Old Mar 22, 2012 | 12:40 AM
stunt2's Avatar
actually wanted to use it on IV and afaik 4-8 heads have same pattern
Old Mar 22, 2012 | 12:52 AM
RSMike's Avatar
Yes they are 100% interchangeable, the Evo 9 headgasket is just 5 layers rather than 3 layers of the Evo 4-8 headgasket.
Here is a pic that i did of "spot the difference" with thicknesses included (mm)
Cheers, Mike
Old Mar 22, 2012 | 01:17 AM
stunt2's Avatar
thanks for that pic mate. upper holes in your pic on IX gasket need redrilling or enlarging ? they seem bit smaller compared to VI gasket
Old Mar 22, 2012 | 10:20 PM
RSMike's Avatar
personally i wouldn't touch it, just chuck it in.
it depends on what compression ratio you want to run, and if you've skimmed and decked your head the evo 9 gasket will help to bring the compression ratio back to what it should be.
There is definitely the rubber around the bores etc on the Evo 9 gasket, it's just not as dark as the Evo 6 gasket.
Cheers, Mike
EVO 4 life
Jun 29, 2016 08:28 PM
dsevo
Jan 1, 2014 09:10 PM
mitsugsx13
Mar 11, 2012 11:34 PM
czilla
17
Feb 1, 2010 12:40 PM
SeanC
Oct 20, 2008 05:14 PM
